- Sep 4, 2003
- Salmon Arm BC CANADA
White Rain said:You could always have 2 seperate computers, one completely beneath the floor except mouse, kboard (wireless versions) and the monitor, a way to power it on. you could then quickly unplug the monitor from the underground pc (using an extension so you can drop the monitor cord that's attached to the back of the pc under the floor down into the floor. mod the keyboard and mouse so that they work on both pc's at the same time because they run on the same frequency, so when you turn the clean pc on the mouse and keyboard would run on it ( would only have one pc on at a time) only suspicious thing is then is that your monitor isn't plugged into the clean pc, to remedy that all you have to do is remove the securing screws from the monitor plug so you can use the excuse you lost them and it falls off the back of the pc all the time on it's own.
I wouldn't go for that idea personally, too complicated and if they were already looking for you they know you have something to hide anyway, so having something like the primacord HDD death box although suspicious would be the best way to prevent your data from falling into the wrong hands.
Pointless i mean there is a good chance they will find it and if they do ur toast.
man dont you get it you wont have time to unhook any thing if your lucky you can press the butten thats all.
i wouldnt even cover the butten with glass i would put a swing cover on it so flip push BOOM.
