- Feb 11, 2010
- Swanton, OH
Yeah, Thermochill makes some top flight rads, that's for sure. And being in the UK, he should be able to get them for a good price too. IMO, they are an even better choice for silent watercooling because of the large FPI of the rad as compared to the Swiftech and would do well with quiet fans such as Yate Loon lows or some 1450 rpm Gentle Typhoon fans. But you would have to go with a separate pump and radiator like Conumdrum stated in post #13. A PA120.3 hung off the back of the case, with a Laing DDC3.2 with an XSPC res top or an MCP655 with a reservoir or T line would definitely do a great job and be nice and quiet.
And definitely do like Conumdrum said and do your research first and thoroughly. Since you are in no cooling bind right now, it will definitely pay dividends and save you money from reading, studying and looking at other people's setups. I researched for several months before I took my initial watercooling plunge back in 2002, but I went straight to using a TEC with my loop too. That required a bunch of extra research. When you are doing subambient cooling, you have some extra steps to go through to keep from frying equipment from condensation.
Are you saying Thermochill is better than Swiftech?
