- Nov 25, 2009
- Thread Starter
- #41
Ok shopping list is looking like this so far:
Swiftech Apogee GTZ: £45.95
Swiftech MCP 655 Pump: £ 65.91 - or would an MCP355 (£54.99) or MCP350 (49.99) be suitable?
Swiftech MCR220 QPK Radiator: £29.34 - 1 to start with just for CPU
Swiftech MCRES: £17.99
Tubing - how much will I need?
Coolant - which to go for
Anything else?
Then once I have the lot setup, I will go on to WC the GPU and chipset:
Second MCR220 QPK Radiator: £29.34
Swiftech MCW60: £39.95 or EK FC4870 CF Full Cover: £64.88 - worth it?
If I stick with the MCW60, would my current Zalman ZM-RHS1 RAM sinks be as good as say Swiftech MC14 (£11.95)? My Gigabyte 4870 already has a large stock MOSFET cooler, but would a Swiftech MC21 be worthwhile for £6.23?:
I would then get either just one Swiftech MCW30 for the Northbridge, or get a second for the Southbridge too.
So 2 radiators and 1 pump should be enough for all that?
I would use my 2 Scythe SFF21E to cool the first radiator, then buy two more for the second.
I would keep the Coolermaster 140mm fan as an intake at the front, and a 120mm exhaust fan in the rear.
Is there anything else I have missed?
Anything else?
