- Dec 18, 2003
- Lorain, ohio
i have a 939 adapter for my XP 90 and i dont want to buy another kit for this pc. i can only fit this in my pc (LianLI V300) with a 92mm fan it pretty much packs the case almost touching the power supply.
looking at the retention plate, i see its similar to the 775 but not quite, but can i modify the plate to look like the other and maybe try to get it to mount? i know i'll have to use screws and such, but thats fine i know there will be some more modifications to get it to fit properly.
or should i make something else? i was thinking of a square plate where the tension is put on the mounting plates and use screws and washers or something? similar to the XP 120 but a little different
