Screens:
p95 blend test 25-30 mins:
bios:
CPU:
Memory:
SPD:
Thanks for any help I can get!
Yeah. so what can I tweak in my BIOS?
Okayy. Thanks for the warning. XD
Are the temps that you refer are w/ blend tests already?
yeah. my other fan was !@#$
so what'll i adjust?
i got a prob
i tried tweaking the clock @ 250(gave up at 260)
then the ram @200
and the multiplier at x6
then the voltage was stock
i turned up the voltage at 1.4 and it worked
but i turned it back to stock then made the clock at 2.5
then my pc powered on, but nothing on monitor.
should i hard reset my CMOS or something?
Mr. Piggy,
Didn't you post about overclocking this same system a couple weeks ago? Seems like I told you then that your temps were too high and that you needed better cooling but you said it wasn't in your budget. Is something different about the system now than then?
