I know...I was shooting for 2.8 though! LOL Thanks for the help Otter...I appreciate it
Here is what I have and the meathod I used lastnight...
1. Max HTT/FSB should be first ..*only works if motherboard has locks. Most A64 boards do today. Sata 1 and 2 are not locked on some nforce mobos use 3 and 4.
- set CPU multi to 6 or 7, this will take CPU out of equation
- set memory to SPD and 100, and set LDT x2 or x3 this will take memory out of equation
- Increase HTT/FSB up until you fail to boot or there abouts, back down 5%, (HTT * 0.95), this is your max safe HTT.
Here are my results with what it was running...
While in windows I hit 365mhz using Clockgen, tried to boot, wouldn't till I lowered to 354mhz
LDT was @ x2
Cpu multi was @ x6
Mem @ SPD and 100
Cpu volts was @ 1.55
HDD is on SATA port 3 non-raid
Here is the second step I did...
2. Max Chip capable
- Set multiplier to it's maxium
-Set vcore to 1.6 -1.65 for 130nm chips, 1.50-1.55 for 90nm chips
-Set mem to SPD and 100, this will take memory out of equation
-starting with HTT 200 raise in about 5Mhz increments up to boards max found earlier or until you start failing PRIME95 which will probably happen first..only give it 5 minutes max, that's good enough for now.
-At the point it starts failing within that 5 min time period, back down 5%, (CPU MHZ * 0.95), thats your max CPU speed, now test prime again at 95% for 12 hour for stable.
I could hit 225mhz and pass Prime for 5 minutes on both cores
230 failed prime within 5 minutes on core 0, core 1 passes as always, did not go higher
LDT was @ x3
Cpu multi was @ x12
Mem was @ Spd and 100
HDD is on SATA 3 non raid
My system will pass prime at 220 for over ten hours. I did not try to pass at 225 again since I am still having the same issues as before. I take it that it's possible that I have one bum core right? This is really aggrivating
