7/27...
Lastnight before going to bed I toyed with the settings a bit as suggested...
LDT - 4x
HTT - 12x
CPU volts - 1.50v
CPU mhz - 225
Mem Volts - 2.8v
Memory settings are as follows:
Timing Mode - Manual
Memclock Index Value (mhz) - 333
CAS# Latency (Tcl) - 2
Min RAS# Active Time (Tras) - 5T
RAS# to CAS# Delay (Trcd) - 3T
Row Precharge Time (Trp) - 2T
Row Cycle Time (Trc) - 11T
Row Refresh Cycle Time (Trfc) - 14T
Read-to-write Time (Trwt) - 4T
Write Recovery Time (Twr) - 3T
1T/2T Memory Timing - 1T
S/W DRAM Over 4G Remapping - Enabled
H/W DRAM Over 4G Remapping - Enabled
Well...I passed a dual prime95 test overnight and as I got up I see it recycled into another pass...so I shut it down. Now...is this because I lowered the mhz to 333 as suggested, or could it be because my Trfc is now at a 14, or probably both? I'd like to see if I could get it up to 2.8 if possible. Also...I posted this in another section, but if I was to let my prime run a few more passes, isn't that harder to pass?
After I got ready for work, I also ran a SuperPI test at 32m, passed that no errors in 29 minutes flat. Also monitoring my cpu temps...seems to be hitting a high of 58c while running these tests, sometimes as low as 56c
