This is my first thread, so bear with me... (hopefully this is detailed enough)
Specs: Abit NF7-S V2.0 (about 6 months old from ZipZoomFly)
AMD XP-MOBILE 2600+ IQHYA (I think that is the stepping, it is
whatever the really good stepping is...cant remember exactly)
1 GB (2x512) Corsair PC3200 XLPT(2-2-2-5 (SPD) platinum heatsinks)
SATA Diamondmax 10 300GB
EVGA Geforce 6800GT
SoundBlaster Audigy 2
ANTEC True Blue 480W
windows xp professional sp2, etc, etc
Cooling: SLK-948U (took me forever to track down like 6 months ago)
& Delta 92mm High speed fan 80 CFM 4000rpm
Arctic Cooling NV silencer 5
Arctic silver 5 thermal paste on CPU and GPU and GPU mem
coolermaster case with 2 x 80 intake fans - panaflo 40 cfm each
and vantec tornado 80mm exhaust, coolermaster generic 80mm top
OC: right now running at 210 x 12 at 1.825 Vcore and 2.8 Vdimm
at 2-2-2-11 timings (1T). cpu at 42.5C idle / 46ish under load
geforce OC'd using coolbits to 415 / 1.13 53C idle / 64 load
The issue I am having is that i cant seem to overclock the fsb any more that 210 because if I do, lets say for example i set the fsb to 215, it will freeze up on me during games, and i have to restart ("sound starts looping" type of crash). What i believe is the issue for this is that because i have the graphics card overclocked a lot it is sucking so much juice that there is not enough for the other components... I originally had my Geforce oc'd higher to like 425 / 1.15 and i couldn't set my FSB past like 206 or it would freeze in games and then blue screen and say something about the nv4_display.dll.. I googled this error and after some research it seemed that this was due to simultaneos overclocks on the fsb and the graphics card on an AGP system. I tried upping the agp voltage but that doesn't seem like it does anything. I would like to oc my computer farther as it appears I am not tapping into the potential of my system..I have seen people with like 260x11 and such. I would like to keep my graphics card oc'd though...it helps out a lot in CS:Source. Also, I am still using the default bios. I did see you guys' big NF7 bios vault...though there are like a 100 freaking ones, I dont have a clue what would work well...as there are no descriptions for each one that tells me what is different than the one above it. I also have not done any voltage modding, though I am in school studying Electrical and Computer Engineering, so if I need to do something like that, thats not a problem.
Anyway, I would really appreciate any thoughts or advice you guys might have... I know there are a lot of experienced overclockers in this forum especially with the type of system I have.
Thanks in advance,
Eric
EVGA Geforce 6800GT
Thanks in advance,
Eric
