- Apr 14, 2007
Hi Guys,
After the price drop the QuadFx is getting better. Friend and I are planning on getting fx74's. My friend is building his system from scratch and I am just updating my motherboard and case. So I need some recommendation for the case, cooling fans and other stuff.
Here is my current config
M2N32
6000+
4gb OCZ rev2 plat
74gb raptor
250g + 160g sata2
P180 case
Zalman 9500
OCZ 850Watt power supply
4 Sony fluid bearing fans
Vista ultimate 64bit
What I am thinking about
FX74
L1N64
Lian Li 2100A case
One R600 + R610
One more Zalamn9500AM2 cooler
two Zalman fan new display mcf2 controllers
And pretty much the same setup for my friend, in terms of the power supply and ram and coolers.
Questions
Case:
Do you think Lian Li 2100 A is a good case. I need a quite computer; I will probably run the CPU's at 2.8 ghz when not playing games.
Motherboard:
I like Nvidia motherboards, and I will probably run ATI cards on this board.I don’t see myself ever doing crossfire, I will probably get one high end R600 and one cheap R610 to drive the 3rd display. Is this board good with Vista ?Should I wait for RD790 Wooho board. Will upgrade in November to the new Quad core processors, man having 8 cores on one system will be amazing, I know it is an overkill but , I always wanted a nice computer.
Coolers:
What are good quite coolers for this setup, Will the Zalaman 9500AM2 work on this board. I have a feeling I need some extra hardware to make this cooler work on this.
M2N32
6000+
4gb OCZ rev2 plat
74gb raptor
250g + 160g sata2
P180 case
Zalman 9500
FX74
L1N64
Lian Li 2100A case
One R600 + R610
Questions
Case:
Motherboard:
Coolers:
