- Dec 15, 2010
- Thread Starter
- #21
You're SURE you have a 400Mhz FSB hole?
400x10 1:1 would be your ideal setting.
UPDATE your bios! . Not sure if your board supports it but if it has EZFlash you can just put the bios on a USB key, enter bios, and tell it to run the new bios off the USB key. Remember that if you have a system powerdown for whatever reason during bios update, your computer will become a paperweight.
SET ALL SETTINGS TO AUTO FOR BIOS UPDATE. DO NOT UPDATE BIOS OVERCLOCKED.
Also update your MB chipset driver in windows from ASUS website to the latest available.
Take a stick of ram out, look at the timings and voltage. (it's on a little sticker on the RAM) Make sure to match in bios.
(ie, 4-4-4-12 in all likelihood. If it's cheaper stuff could be 5-5-5-15 or 18.) Double check your electrical connections and CPU heatsink seating while you're in there.
Your RAM is not limiting your overclock, you're just misunderstanding how the RAM:FSB ratio works.
The guides about various architechtures and how to overclock them (ie, Core 2) are really well written. I had to read the one for my new system (in sig) several times to wrap my head around the very different architechture of i7 vs C2 but eventually I got it.
C2, tweak wise, is very simple comparatively IMO. I think you pretty much get it. If you read up on RAM timings and FSB:RAM ratio I think you're good.
According to the short lived Terminator TV series the CPU for a T-800 runs at 5V so pretty soon you won't have to worry about overvolting if that's any comfort (your avatar made me think of this). Hehehehe.
Your computer will also be mobile, robust, look like a dude, and be looking for a kid named John Connor but when you can manage to get it to stay home it'll probably run Crysis wicked good.
Funny guy.. lol
Hi, my multiplier is locked to 9 therfore its not 1:1, its something like 4:3 or something with 611mhz at 1.8 v. I can put the ram mhz to 811 or so but with 1.95v, its still unstable though and blue screens etc, the ram is crap so I dont want to stress it with 2.0V or over. anyway, your right about the fsb:ram ratio, i dont know how it works. there are no timings on the ram sticker, in fact I just set the timings to manual in the bios and left it there as all the timings come up automatically and I dont want to mess with something I dont know much about.
Now for the "1.37 is nothing", oh ok, when I go home, ill try 1.4v with 410mhz cpu frequency.
I have updated the bios to that of 3001. there is only one update which is 3002, Ill update it to that one when I go home too.
And I use Driver genius Pro to update the drivers for the NB, they seem all updated.
With a settings of 1.31v Vcore set at 407mhz x 9, ther cores do not reach above 59.C and Cpu never seems to go over 31.C, this is why I am eager to overclock it to even MORE!!!! Muwahahahaha.
I just need you guys to carry on helping my poor little soul..
