- Sep 13, 2015
- Thread Starter
- #41
I have done that before. I've found two things. If everything else is good it's not necessary and getting eraser out of the pins in the socket is nearly impossible. I have had it "squish" under the CPU before while clamping and that's when I decided I was further ahead without it. I haven't lost a board or CPU to water since my very first DICE attempt two years ago. So it does work.
That is what I was worried about with the pins in the socket. I destroyed one of these boards before and don't want to do it again. I will stick with the ring of eraser for now.
I need to order some more eraser as well as some armaflex and TIM. I'm just waiting for prime day on the 12th to see if I can get any good deals. Any recommendations on good TIM for LN2 use. I traditionally use cooler master ice fusion for my bulk needs and gelid gc extreme for my dellided chips, don't know how either of these will hold up at low temps though.
I did find another Stanley thermos at the local hock shop for a dollar so snatched that up quick. That gives me 2 - 1 liter thermoses and I found a cheap 2 liter thermos on Amazon I will probably get.
