- Jun 22, 2010
Hey guys hope you can help
i have built a few pc in the past with no problems.
i recently bought all new stuff to build a decent rig, that went all good.
then i thought why not make a crappy pc for muck around stuff so i scraped all my old part together and built one but when i turned it on no post beeps or any sounds (cpu fan spins perfectly dosent stop).
so i decided to bench test it out side of the case (was told it could be short from the metal)
all that was plugged in was cpu/fan, cmos battery, 24 pin atix and 4 pin atix
and the power switch from case, the same thing happens fan spins no sound/beeps..
so i grab another motherboard i have and the same thing happens, i did this five times (yes i have 5 mobo they all have diff chips in it ) they all did the same thing, also reset the cmos battery, thought ok its must be the power supply got one that works (took it out of a working pc) the exact same thing happens.
so last thing i thought it must be the case (power switch cord) same thing happens!!!! with new case
I really dought that 5x mobos and 2x psu would just die when i was using em like month ago, (like i would be ok if something different happen to each one like beeps)
