- Jan 12, 2012
If it's for gaming, unless it's a cpu bound game, squeezing the last few stable mhz out of the chip probably isn't going to give you much more performance. I would just follow my advice above find a 2 hour prime stable point either 3.7 or 3.6 and then start pushing it again. Another option, since most games do not utilize multi core processors, you may try shutting down 2 of the cores, "if possible" and see if you can push higher. If you have indeed hit a wall, either temp or cpu then you next step may be pushing the OC on the 460.
Ummm yeah! FYI when I'm stable 2 hours prime I can fold 24/7 for days upon end which is pretty taxing on the stability.I don't do any folding (except laundry and that's no fun).
