- Jul 30, 2014
Hi All,
Just wanting some advice on how to fix my MBR and BCD for my Windows Vista machine w/o having to reinstall Windows.
I know that you are able to repair via install disk which worked fine once in the past however this time its not working. I have a feeling its what is causing my machine to say there is no detected Master in my BIOS.
I have tried to Windows disk which doesn't work I have also tried to remove and put a clean BCD down which didn't seem to work have tried to use repair tool to repair BCD and MBR and I am having no luck at all.
I am trying AOMEI Partition assistant but the option to fix the MBR isn't coming up is this due to me being in the OS? Would I have to boot the HDD through another machine as the slave so the OS on the other machine is the Master to have access to alter the MBR?
Is AOMEI reliable to do the job if anyone knows??
Is there any software that is free I can use that will 100% fix both my BCD and MBR??
I would really appreciate some help on this topic as I would like to ensure everything is in working order prior to me starting to overclock my machine (waiting on my parts to arrive).
Thanks all for the help in advance.
