Help to overclock e4600
Micun
Hi mates. I am new to this forum and also new to overclocking.I need little help to overclock core 2 duo e4600 processor.I had read that this processor is very easy to overclock without increasing vcore to 3.0 so that is my goal. Firstly I will give you info of my com:
CPU Type DualCore Intel Core 2 Duo E4600, 2400 MHz (12 x 200)
CPU Alias Conroe-2M
CPU Stepping M0
Instruction Set x86, x86-64, MMX, SSE, SSE2, SSE3, SSSE3
Original Clock 2400 MHz
Min / Max CPU Multiplier 6x / 12x
Engineering Sample No
L1 Code Cache 32 KB per core
L1 Data Cache 32 KB per core
L2 Cache 2 MB (On-Die, ECC, ASC, Full-Speed)
Motherboard Name ASRock 775i65G
http://asrock.com/mb/overview.asp?Model=775i65G
Front Side Bus Properties
Bus Type Intel AGTL+
Bus Width 64-bit
Real Clock 200 MHz (QDR)
Effective Clock 800 MHz
Bandwidth 6400 MB/s
Memory Bus Properties
Bus Type Dual DDR SDRAM
Bus Width 128-bit
DRAM:FSB Ratio 1:1
Real Clock 200 MHz (DDR)
Effective Clock 400 MHz
Bandwidth 6400 MB/s
Chipset Bus Properties
Bus Type Intel Hub Interface
Bus Width 8-bit
Real Clock 67 MHz (QDR)
Effective Clock 267 MHz
Bandwidth 267 MB/s
Motherboard Physical Info
CPU Sockets/Slots 1 LGA775
Expansion Slots 3 PCI, 1 AGP, 1 AMR
RAM Slots 2 DDR DIMM
Integrated Devices Audio, Video, LAN
Form Factor Micro ATX
Motherboard Size 200 mm x 240 mm
Motherboard Chipset i865G
Extra Features Hybrid Booster
Module Name Kingston K
Serial Number 710EF037h (938479217)
Manufacture Date Week 32 / 2008
Module Size 1 GB (2 ranks, 4 banks)
Module Type Unbuffered
Memory Type DDR SDRAM
Memory Speed PC3200 (200 MHz)
Module Width 64 bit
Module Voltage SSTL 2.5
Error Detection Method None
Refresh Rate Reduced (7.8 us), Self-Refresh
Memory Timings
@ 200 MHz 3.0-3-3-8 (CL-RCD-RP-RAS) / 11-14-2 (RC-RFC-RRD)
@ 166 MHz 2.5-3-3-7 (CL-RCD-RP-RAS) / 10-12-2 (RC-RFC-RRD)
North Bridge Intel Springdale-G i865G
Supported FSB Speeds FSB400, FSB533, FSB800
Supported Memory Types DDR-266 SDRAM, DDR-333 SDRAM, DDR-400 SDRAM
Maximum Memory Amount 4 GB
Revision / Stepping 02 / A2
Package Type 932 Pin FC-BGA
Package Size 3.75 cm x 3.75 cm
Core Voltage 1.5 V
In-Order Queue Depth 12
Memory Controller
Type Dual Channel (128-bit)
Active Mode Dual Channel (128-bit)
PAT Disabled
Memory Timings
CAS Latency (CL) 3T
RAS To CAS Delay (tRCD) 4T
RAS Precharge (tRP) 4T
RAS Active Time (tRAS) 8T
Refresh Period (tREF) 7.8 us
Video Adapter Leadtek WinFast A400 GT ( Geforce 6800 GT )
BIOS Version 5.40.02.32
GPU Code Name NV40GT
PCI Device 10DE-0045 / 107D-2996 (Rev A1)
Transistors 222 million
Process Technology 0.13 um
Die Size 287 mm2
Bus Type AGP 8x @ 8x
Memory Size 256 MB
GPU Clock 351 MHz (original: 350 MHz)
RAMDAC Clock 400 MHz
Pixel Pipelines 16
TMU Per Pipeline 1
Vertex Shaders 6 (v3.0)
Pixel Shaders 16 (v3.0)
DirectX Hardware Support DirectX v9.0c
Pixel Fillrate 5616 MPixel/s
Texel Fillrate 5616 MTexel/s
Bus Type GDDR3
Bus Width 256-bit
Real Clock 501 MHz (DDR) (original: 500 MHz)
Effective Clock 1002 MHz
Bandwidth 31.3 GB/s
That is my specif.I have intel stock cooler.Do I need to buy new one for 3.0mhz if I could reach it? I read that if I increese FSB to 250 I will have 3.0mhz and I have to slow down ram to ...? Can some one tell me exaxtly what memory timeings for ram and other?
And what this means for my MB:
Only supported with PCB version R2.00 or higher, and BIOS P2.80 or higher.
**FSB1066-CPU is supported by overclocking only when you adopt an external VGA card and DDR400 CL2.5 memory modules.
Thanx
Yes I forgot. My PSU is ATX 400W
If you raise the FSB to 250 MHz at a 1:1 FSB : DRAM ratio, the resulting DRAM frequency would be DDR-500 which is well above the rated DDR-400 RAM that's currently installed. You would either need to increase the DRAM voltage (VDDQ +1.58V Voltage), and / or loosen the primary DRAM timings from the default of 3-3-3-8 at 200 MHz to something along the lines of 4-4-4-8 at 250 MHz.
