Thanks RGone, Johan45 and Trents,
"As to point number 2 If you're talking about the PCIEx1 slot being covered which I assume you are. That card will work in one of the othe PCIE slots. The gold connector has the same cut out it's just alot shorter."
- Ah ok. I just went with the instructions from the manual advising to use Slot 1 for only 1 GPU. May move it at some stage but sitting nicely at the moment ;-)
"Welcome to the Sabretooth owners club Zorton"
- Many Thanks....and Yep, its a cracking board - very, very good board and a beauty to look at. Cant believe it can hold 3 GPUs in a 3-way SLI..Not that I will be attempting that myself.
"And I always run P95 Blend on my systems at stock speeds and voltages just to "establish" a baseline before overclocking begins"
- As per recommendation - gonna do this tonight.
"HWMonitor of course shows Min/Max for Volts and Temps"
- I installed HWMONITOR and CoreTemp.
Please see the following for temps whilst just running Internet and Word:-
Are these high/low/average ?
"Did you get the cooler mount issue sorted out?"
- I haven't touched since. I only applied a pea size amount of AS5, but when I went to use the clamp to screw in place, it slided and moved quite badly. I was afraid I was putting too much pressure on the CPU and mobo. To be honest, I would imagine its ok but not sure.. If I have to reapply again, I will, but dont want to remove the mobo from the case and disconnect all cables again. Please no!!
"Tighten the screws until they bottom out. You cannot over-tighten them"
- Does this mean you can continue to screw clockwise but the screw goes no further ?
Yes, this is what it means. The screw has a shoulder above the threads that causes it to stop as I recall.
Anyhow, I will report back with my Prime95 results tomorrow. I have installed GPU tweak for my 660ti as it can be OCd to 110% performance easily according to vid I saw on Youtube.
My final concern relates to the fans. Quite confusing.
My understanding in relation to the Zalman Z11 case is as follows:-
1. The 2 side 80mm fans using Moulex are exhaust fans that blow the air out through the vents.
2. The 120mm fan at the back is an exhaust.
3. The 120mm fan at the front is an intake.
4. The 120mm fan at the top is an exhaust.
Based on this, should I install a 120 or 140 intake fan at the bottom next to the PSU ?
Also, I installed the PSU with the FAN faced down as instructed. Was this correct.
Many thanks for the super information guys. Its hugely appreciated.
EDIT - Can someone post a link for the latest version of PRIME95 for AMD CPUs on 64bit Win 7?
