- Aug 30, 2005
- Bradenton, FL
Trying to determine what is causing me crash occasionally. It happens a few times a week a most, rarely more than once a day. This is the mini dump. I have ran memtest before, and got 0 errors for about 9 hours.
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.1.7600.2.0.0.256.1
Locale ID: 1033
Additional information about the problem:
BCCode: 124
BCP1: 0000000000000000
BCP2: FFFFFA8007E0B038
BCP3: 0000000000000000
BCP4: 0000000000000000
Problem signature:
Locale ID: 1033
BCCode: 124
Code:
Microsoft (R) Windows Debugger Version 6.2.9200.20512 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [Z:\Windows\Minidump\082814-11668-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y <symbol_path> argument when starting the debugger. *
* using .sympath and .sympath+ *
Unable to load image ntoskrnl.exe, Win32 error 0n2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows 7 Kernel Version 7600 MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Machine Name:
Kernel base = 0xfffff800`03057000 PsLoadedModuleList = 0xfffff800`03294e50
Debug session time: Thu Aug 28 20:02:31.116 2014 (UTC - 4:00)
System Uptime: 0 days 0:00:07.505
Loading Kernel Symbols
Loading User Symbols
Mini Kernel Dump does not contain unloaded driver list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 124, {0, fffffa8007e0b038, 0, 0}
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
*** Either you specified an unqualified symbol, or your debugger ***
*** doesn't have full symbol information. Unqualified symbol ***
*** resolution is turned off by default. Please either specify a ***
*** fully qualified symbol module!symbolname, or enable resolution ***
*** of unqualified symbols by typing ".symopt- 100". Note that ***
*** enabling unqualified symbol resolution with network symbol ***
*** server shares in the symbol path may cause the debugger to ***
*** appear to hang for long periods of time when an incorrect ***
*** symbol name is typed or the network symbol server is down. ***
*** For some commands to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: nt!_WHEA_ERROR_RECORD_HEADER ***
*** work. ***
Unable to load image PSHED.dll, Win32 error 0n2
*** WARNING: Unable to verify timestamp for PSHED.dll
*** ERROR: Module load completed but symbols could not be loaded for PSHED.dll
*** work. ***
*** Type referenced: pshed!_WHEA_ERROR_RECORD_HEADER ***
*** work. ***
*** Type referenced: pshed!_WHEA_ERROR_RECORD_SECTION_DESCRIPTOR ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** Type referenced: nt!_KPRCB ***
*** work. ***
*** work. ***
