Give the CPU_NB about 1.225V and the NB about 1.15V
Microsoft (R) Windows Debugger Version 6.2.9200.20512 X86
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [Z:\Windows\Minidump\082914-10951-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y <symbol_path> argument when starting the debugger. *
* using .sympath and .sympath+ *
Unable to load image ntoskrnl.exe, Win32 error 0n2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows 7 Kernel Version 7600 MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Machine Name:
Kernel base = 0xfffff800`0301b000 PsLoadedModuleList = 0xfffff800`03258e50
Debug session time: Fri Aug 29 23:48:32.476 2014 (UTC - 4:00)
System Uptime: 0 days 0:00:06.881
Loading Kernel Symbols
Loading User Symbols
Mini Kernel Dump does not contain unloaded driver list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 124, {0, fffffa8007ddb038, 0, 0}
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
*** Either you specified an unqualified symbol, or your debugger ***
*** doesn't have full symbol information. Unqualified symbol ***
*** resolution is turned off by default. Please either specify a ***
*** fully qualified symbol module!symbolname, or enable resolution ***
*** of unqualified symbols by typing ".symopt- 100". Note that ***
*** enabling unqualified symbol resolution with network symbol ***
*** server shares in the symbol path may cause the debugger to ***
*** appear to hang for long periods of time when an incorrect ***
*** symbol name is typed or the network symbol server is down. ***
*** For some commands to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: nt!_WHEA_ERROR_RECORD_HEADER ***
*** work. ***
Unable to load image PSHED.dll, Win32 error 0n2
*** WARNING: Unable to verify timestamp for PSHED.dll
*** ERROR: Module load completed but symbols could not be loaded for PSHED.dll
*** work. ***
*** Type referenced: pshed!_WHEA_ERROR_RECORD_HEADER ***
*** work. ***
*** Type referenced: pshed!_WHEA_ERROR_RECORD_SECTION_DESCRIPTOR ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** Type referenced: nt!_KPRCB ***
*** work. ***
*** work. ***
Probably caused by : AuthenticAMD
Followup: MachineOwner
still think its clearly a voltage only issue?
Looks like I would try more Vcore. It may be an L3 cache error.
OK. Time for the question that nobody has asked. What PSU?
I'd be testing that PSU. Bad power causes all sorts of weird issues.
PSU is good
And you know this how? Earlier in the thread you stated you had no extra parts to test with.
