Hi I'm new, I hope i can become a valued member soon.
I purchased a laptop in Korea not long ago, i came with the option of Win7 or 8 but i chose to get it without an OS because I didnt want an OS in hangul. I installed Windows 7 on it and I've been using it fine ever since. Now I have decided to move on to Windows 8. And since my laptop has UEFI capabilities I might as well go all out.
But, I want to make sure I do it properly and I would like to understand a few things first.
In my bios I have the following settings (I'm only listing the things that would have something to do with UEFI or things I have no idea about.
ADVANCED:
XHCI - It's set to Auto, other options include Enabled, Disabled and Smart Auto. I have no idea what this function is and i assume i should leave it.
HDC Configure As - I have no idea what this is either and it's set to AHCI. Other option is IDE.
VT Suport - Whatever it is its enabled.
BOOT:
Boot Type - Set to Dual Boot Type - I guess I will change that to UEFI when I go to install Windows 8.
Skip EFI Image in CdROM - I should disable that I guess/
__
SOOooo.. Is there anything I should know about, especially about the settings in the Advanced section? If someone could explain what they are I would appreciate it very much. I'm greatful for any tips you guys could provide.
Thanks in advance!
ADVANCED:
BOOT:
__
Thanks in advance!
