- Jul 22, 2013
- Canada
- Thread Starter
- #21
Ok, so I ran a 4.0 Ghz Prime95 small FFT test with stock voltages vcore 1.344 "Normal" LLC for 20 mins. No errors currently.
CPU
Memory
SPD
HWMonitor
Rgone, I used your recommended timings of 9-9-9-24-41 and 2 command rate. For some reason those fields are blank on CPU-Z.
Mandrake, I also read into the Pll you referred to and I think I'll try nudging the voltage up slightly, seeing as I have a GB mobo.
In the mean time I'm going to try going for 4.5Ghz again with HT at 2600Mhz, NB at 2200Mhz NB at 1.25v, RAM at 1600Mhz. I'll be upping multiplier and using FSB at 200 for now, but I want to tinker with FSB later.
EDIT: I have 2 NB settings, one for the CPU NB and one for (i'm assuming) the mobo NB chip. The core voltage for CPU NB is an offset... should I be adjusting this as well?
I do have one question though; Now that my RAM timings are at a more acceptable setting, how much of an FSB adjustment can I make before i have to loosen them? If I run a higher FSB can I drop my memory ratio/HT/NB multipliers to compensate? I've used 209, 228 in previous overclocking attempts.
CPU
Memory
SPD
HWMonitor
