- Dec 1, 2008
- Last 30 Years NE OH
On my Gigabyte 970 I have board revision 1.1. I have noticed that on some board revisions and bios updates, they are excluding some important overclocking features.(ie) Like taking load line calibration out of the mix. I had mine set to extreme to compensate for v-droop, but still had one major issue. The vrm control on 970 boards is jumpy. It always fluctuates back and forth. Fluctuation is normal, but these boards have poor vrm control. No big deal. I fixed that problem by using a fixed voltage at 1.27v on stock settings, and of course my overclock is set at a fixed voltage. Every motherboard is different, along with the cpu, so results will vary. Overall case cooling is very important imo. I have good airflow across the motherboard, which is a must for higher overclocks. How are your north-bridge temps ? On stock mine stay around 30c or below. Prime testing will increase that to 60C - 65C. Why the big increase ? The NB heatsink is pretty dinky for the job it has to do on these boards. You'll notice alot of hard core overclockers are using better motherboards to push there cpu's.The Asus Crosshair, ROG boards, ect... One advantage with the 6300 is its rated at 95 watts vs 125watts. Follow the advice of some of the older members here.They have overclocking AMD cpu's down to a science.
