...Man you do GooD work with those drawings. Wish I could do as well. NICE.
I see nothing wrong in general with your "hanging" fan other than it needs ACCESS to cooler outside air, if at all possible. I have in situations like yours with older cases; had to drill a pattern of holes in front of case level with a fan for it to have ACCESS to outside the case, cooler air.
AND understand this...getting cooler air IN and warmed air OUT of a case is just good sense for use over the long haul. Cool is always better on over-clocked and over-volted electronic parts. You can "never" get enough added cool air in and out of case...at least enough more cooling air than when you started modding, but even so you remove yourself and system further and further away from possible heat issues with HoT FX processor by any additional cool air into case and then gone when warmed. Luck man. Nice work to date.
RGone...ster.
Then you're too hot, back it down.
y i know, but ingame i reached max 35 degrees
Hi,that 4.7 ghz it's without touching fsb and other voltages.you're only reaching 35c in game?
this tells me you're not useing all 8 cores in game and you can disabe 2 or four.
you can spend a whole lot of time fighting ram to improve game but it will never buy you anything you will ever see, I have been there and done that, from 800 to 2400, you will never "see" it.
open your task manager, click the performance tab, play your game windowed and watch the loading on the cores, my bet is that you only see 2 or four at max doing anything.
what game are you playing????
It is good practice to always say my CPU/Socket Temp was Xc and my Cores/Package Temp was Xc. Actually I almost always give BOTH temps because in HoT FX processor land, both temps really mean something to the overall deal.
Here is how most of us that help people overclock here in this forum section think about an overclock. We only believe in and coach full stability. We do this because we do real work on our computers or some of us do. Gaming only stable on the lesser cpu intensive games would be a complete washout and kick in the head for me when I am video editting. It is a real kick in the head to be half way thru an edit and have my computer crash and maybe take my operating system and lose more time used in arranging my videos than it will take to do the render.
Now we do bench and it is done at outrageous speeds far beyond anything called stable. Now I cannot speak for others but in benching, I am even prone to unhook drives not used in benching but hold my video data so hopefully no chance of losing hours of work.
So because of the too many variables from user to user...we stress 2 hours of stability testing using P95 Blend mode and that then is the speed we most often are speaking about and referring to. Seldom ever do we mention Ultra Fast Cpu Clocks since we have no intention of mis-leading the unwary to consider gaming stable with true and actual considered stability. Now you know more of the rest of the story. Luck man.
RGone...ster.
RGone...ster.
bsod's are to be avoided, they prove that we are unstable, they corrupt our operating system and that, in itself makes us unstable.
witcher 3 is about the gpu, but, the cpu has to feed the gpu.
in all my gpu games I find that piledriver cores need to run at 4.5 or so to not bottleneck the system, in the games that are about the cpu cores I find that if I can get them above 5.0 or higher they run better, if I can get it stable.
5.0 stable will always play smoother than 5.2 unstable.
continue clocking please.
That's only in that game, if you were to play something more intensive as I hear BF4 is your PC will likely overheat and shut down. It's up to you what you do with your system but if you don't get some sort of stability you WILL run into problems, most likely sooner than later.
+1...Good deal man. I see you got the drift of stable and not 24/7 work stable and I see you also use different saved bios presets for various games. Says you are not wandering around aimlessly. Hehehe. You have a better idea what and how you need to setup to do your 'stuff'. Luck man.
RGone...ster.
+1
But just a thought, since there is little difference performance wise between a couple hundred Mhz overclock, why bother taking the time to switch? Just run something stable is my take. Save yourself time and effort.
It is more time and effort to reboot, go into bios, enable profile and boot again. Or in windows, to open up the program and click than it is to not have to do any of that stuff and sit at a known stable clockspeed. Your choice of course. I value my time, even if its 30 seconds to reboot, or 10 seconds to switch profiles in windows.
Either way.. enjoy that PC!
