I just bought a Prolimatech Armageddon 1156/1366 cpu cooler and I have trouble getting the backplate tight. The backplate does fit the motherboard and the rivet nuts go through the holes in the mobo just nicely, but it will be loose. The screws in the backplate holes slightly move when you fiddle with them. I think this is because I just don't understand the first step in the install instructions where it says "remove the rivet nuts". I don't see any removable parts and I'm afraid to do anything by force... this is the first time I'm putting in a custom cooler. I found a link to similar instructions, there if you scroll down a bit you can see a close-up view of the instructions and the "remove the rivet nut":
http://www.tweaknews.net/reviews/prolimatech_megahalems_rev_b_review/index4.php
I tried to continue building on the backplate on the front side of the mobo, like screwing the other parts in place (except the cooler itself) but it didn't help. I'm definitely not getting something here...
Here's also a link with the same backplate and rivet nuts:
http://www.clunk.org.uk/reviews/prolimatech-genesis-cpu-cooler-review/Page-6.html
Any ideas? Thanks in advance!
CPU: Intel i5-750 2,66Ghz
Mobo: Asus P7P55D Deluxe
