HKCU isn’t in reg that I can see HKLM is in reg
So I looked in all of the categories with software in them and I still cant find it
thanks for your input
Did you use the search function of regedit to find HKCU? You can search then delete every instance of HKCU -(pree F3 after each deletion to find next). Or just use System Restore function to go back to befor this item showed up. Been looking at naughty Anime sites?
