Hi- just joined the forum! I recently built a new machine- my first PC build since 2007! I was using an Alienware M17x R3 laptop since early 2011, but that recently died, so I decided to go back to desktop PCs. I have a reasonable amount of experience building PCs and tinkering, but I have never really done any overclocking.
I dove in head first over the weekend after running the machine stock for about a week and needed a little help understanding what the different BIOS settings do.
First, here are the basic specs:
5820K CPU
MSI X99a Gaming 9 Ack Mobo
G.Skill 4x8GB 2400mhz RAM
Corsair H110iGTX Cooler
MSI Gaming 6G 980ti GPU
Phanteks Enthoo Evolv ATX Case
Here's what I've determined so far:
The system runs "stable" at 4.4GHZ at 1.18v. When I say stable, I ran the Aida64 stress test with all options checked for 4 hours and there were no errors reported. Max CPU temps stabilized at between 67-71C. I also tried running a Handbrake 1080P encode (x264 profile 4.1, high bit rate, set to "very slow") and it would stop randomly (but not "crash") at lower voltage settings of 1.165 and 1.175v. 1.18v seems to work at 4.4ghz. I also ran Intel XTU CPU test at 1.18v for 30 minutes and it passed with max temps reaching 67C.
And here is the goal:
I want the system to scale CPU speed and voltage to save energy and run quietly for everyday use, but with a higher max "turbo" setting enabled. The max temps are pretty well handled by the cooling setup, but the idle temps at 4.4GHZ are way too high for my taste (46-49c), and the fans are spinning at 50-60% speed at idle, which makes it too noisy for just surfing the web and doing normal stuff.
Assuming that 4.4ghz at 1.18v is a stable setting, how can I set the OC in BIOS to use that as an effective "maximum" speed and max. voltage (within a couple tenths I assume)? I know it has something to do with adaptive voltage and setting a positive offset, but I can't find concrete info from MSI. Every mfr uses slightly different names for the settings and I don't like to guess.
Anyone with familiarity of MSI Gaming BIOS settings willing to help me out?
Thanks!
Dion
5820K CPU
Thanks!
Dion
