AoiKunieda
- Sep 14, 2013
Hello everyone,
New to the overclocking scene and wanted to try it out a relatively old computer as debut, I found this (splendid) thread from someone with the same computer, it helped me a lot, with it I did the temprature checks and and brought the PC in steps from 2.0 ghz to 2.2ghz, all while taking care of the HT link not getting too high.
However, there is a problem: I just can't change the voltage, unlike the guy in this thread who has problems with it at first as well, I can't even change it 'in crude steps' like he did.... Only place where I can find my Vcore voltage is under hardware monitor, in which I can not change it.
I don't know if it's due to this, but under advanced I got Jumperfree (''config system frequency/voltage'') of course. But I can only change AI overclocking, which is the only option in there, to 'manual', 'auto', or 'standard' (changed it to manual of course to change change the cpu bus frequency)
According to part of the manual of my PC, there should be two more options....
Long story short: is there anyway to make those options appear? Or should there be another way of changing the voltage without it? Also, is it dangerous to remain like this, with 0.2 ghz 'upgraded' and no voltage increase?
Sorry for my bad English and noobishness and thanks for answers beforehant
EDIT: I just upped it to 2.25 GHZ for testing sake and it didn't boot anymore, I presume that 2.2 is indeed the limitation with my current voltage (unless I need to change something else which I don't know about yet). Really hope that someone can me solve this.
