- Dec 25, 2007
- Drunken Stupor, UK
Help with starting up -FIXED-
I have a pentium 640, overclocked slightly, running with HT enabled. I've read a number of guides on this forum and I worked out that I could use the 1 click installer to instal 2 instances of FAH onto my PC and have them both running using the 2 threds.
Beow are the two FAHlog.txt files:
and the other one:
Adak requested I do this to check the instability of my system so here is my setup:Welcome JH258 and SkuTov!
Edit: SkuTov, I see here:
http://folding.extremeoverclocking.com/user_summary.php?s=&u=309642
that you've turned in 3 Work Units (WU's), but none of them were finished. I believe your computer may be unstable at it's current overclocked speed. FAH will stress stability more than most benchmark programs. Can you post up in a new thread, below, and copy & paste what the FAHlog.txt file shows?
Getting started is always the hardest thing, but we try to keep it fun, too!
Code:
--- Opening Log file [December 29 22:00:28]
# Windows Console Edition #####################################################
Folding@Home Client Version 5.02
http://folding.stanford.edu
Launch directory: C:\Program Files\FAH\FAH1
Executable: C:\Program Files\FAH\FAH1\FAH502-Console.exe
Arguments: -local -service -advmethods -verbosity 9 -forceasm
Warning:
By using the -forceasm flag, you are overriding
safeguards in the program. If you did not intend to
do this, please restart the program without -forceasm.
If work units are not completing fully (and particularly
if your machine is overclocked), then please discontinue
use of the flag.
[22:00:28] - Ask before connecting: No
[22:00:28] - User name: SkuToV (Team 32)
[22:00:28] - User ID: 644E3621260A0E40
[22:00:28] - Machine ID: 1
[22:00:28]
[22:00:28] Work directory not found. Creating...
[22:00:28] Could not open work queue, generating new queue...
[22:00:28] + Benchmarking ...
[22:00:30] The benchmark result is 3852
[22:00:30] - Preparing to get new work unit...
[22:00:30] + Attempting to get work packet
[22:00:30] - Will indicate memory of 2047 MB.
[22:00:30] - Autosending finished units...
[22:00:30] - Connecting to assignment server
[22:00:30] Connecting to http://assign.stanford.edu:8080/
[22:00:30] Trying to send all finished work units
[22:00:30] + No unsent completed units remaining.
[22:00:30] - Autosend completed
[22:00:33] Posted data.
[22:00:33] Initial: 41AB; - Successful: assigned to (171.65.103.162).
[22:00:33] + News From Folding@Home: Welcome to Folding@Home
[22:00:34] Loaded queue successfully.
[22:00:34] Connecting to http://171.65.103.162:8080/
[22:00:41] Posted data.
[22:00:43] Initial: 0000; - Receiving payload (expected size: 3059760)
[22:03:36] - Downloaded at ~17 kB/s
[22:03:36] - Averaged speed for that direction ~17 kB/s
[22:03:36] + Received work.
[22:03:37] + Closed connections
[22:03:37]
[22:03:37] + Processing work unit
[22:03:37] Core required: FahCore_78.exe
[22:03:37] Core not found.
[22:03:37] - Core is not present or corrupted.
[22:03:37] - Attempting to download new core...
[22:03:37] + Downloading new core: FahCore_78.exe
[22:03:37] Downloading core (/~pande/Win32/x86//Core_78.fah from www.stanford.edu)
[22:03:38] Initial: AFDE; + 10240 bytes downloaded
[22:03:38] Initial: 2993; + 20480 bytes downloaded
[22:03:39] Initial: 4590; + 30720 bytes downloaded
[22:03:39] Initial: 1F95; + 40960 bytes downloaded
[22:03:39] Initial: 6459; + 51200 bytes downloaded
[22:03:40] Initial: FD92; + 61440 bytes downloaded
[22:03:41] Initial: 62E6; + 71680 bytes downloaded
[22:03:41] Initial: 1F03; + 81920 bytes downloaded
[22:03:42] Initial: 1707; + 92160 bytes downloaded
[22:03:43] Initial: 8862; + 102400 bytes downloaded
[22:03:44] Initial: B1CE; + 112640 bytes downloaded
[22:03:45] Initial: D9DE; + 122880 bytes downloaded
[22:03:46] Initial: 5C0A; + 133120 bytes downloaded
[22:03:47] Initial: 3FF3; + 143360 bytes downloaded
[22:03:48] Initial: 4529; + 153600 bytes downloaded
[22:03:48] Initial: 635C; + 163840 bytes downloaded
[22:03:48] Initial: 869F; + 174080 bytes downloaded
[22:03:49] Initial: C8A8; + 184320 bytes downloaded
[22:03:49] Initial: 1A54; + 194560 bytes downloaded
[22:03:50] Initial: BDCB; + 204800 bytes downloaded
[22:03:50] Initial: CC8C; + 215040 bytes downloaded
[22:03:51] Initial: 12EB; + 225280 bytes downloaded
[22:03:51] Initial: 4886; + 235520 bytes downloaded
[22:03:51] Initial: 29D0;
--- Opening Log file [December 29 22:03:56]
Warning:
use of the flag.
[22:03:56] - Ask before connecting: No
[22:03:56] - User name: SkuToV (Team 32)
[22:03:56] - User ID: 644E3621260A0E40
[22:03:56] - Machine ID: 1
[22:03:56]
[22:03:56] Loaded queue successfully.
[22:03:56] + Benchmarking ...
[22:03:58] The benchmark result is 3972
[22:03:58]
[22:03:58] + Processing work unit
[22:03:58] - Autosending finished units...
[22:03:58] Trying to send all finished work units
[22:03:58] + No unsent completed units remaining.
[22:03:58] - Autosend completed
[22:03:58] Core required: FahCore_78.exe
[22:03:58] Core not found.
[22:03:58] - Core is not present or corrupted.
[22:03:58] - Attempting to download new core...
[22:03:58] + Downloading new core: FahCore_78.exe
[22:03:58] Downloading core (/~pande/Win32/x86//Core_78.fah from www.stanford.edu)
[22:03:59] Initial: AFDE; + 10240 bytes downloaded
[22:04:00] Initial: 2993; + 20480 bytes downloaded
[22:04:00] Initial: 4590; + 30720 bytes downloaded
[22:04:01] Initial: 1F95; + 40960 bytes downloaded
[22:04:01] Initial: 6459; + 51200 bytes downloaded
[22:04:01] Initial: FD92; + 61440 bytes downloaded
[22:04:01] Initial: 62E6; + 71680 bytes downloaded
[22:04:01] Initial: 1F03; + 81920 bytes downloaded
[22:04:02] Initial: 1707; + 92160 bytes downloaded
[22:04:02] Initial: 8862; + 102400 bytes downloaded
[22:04:02] Initial: B1CE; + 112640 bytes downloaded
[22:04:02] Initial: D9DE; + 122880 bytes downloaded
[22:04:02] Initial: 5C0A; + 133120 bytes downloaded
[22:04:02] Initial: 3FF3; + 143360 bytes downloaded
[22:04:03] Initial: 4529; + 153600 bytes downloaded
[22:04:03] Initial: 635C; + 163840 bytes downloaded
[22:04:03] Initial: 869F; + 174080 bytes downloaded
[22:04:03] Initial: C8A8; + 184320 bytes downloaded
[22:04:03] Initial: 1A54; + 194560 bytes downloaded
[22:04:04] Initial: BDCB; + 204800 bytes downloaded
[22:04:04] Initial: CC8C; + 215040 bytes downloaded
[22:04:04] Initial: 12EB; + 225280 bytes downloaded
[22:04:05] Initial: 4886; + 235520 bytes downloaded
[22:04:05] Initial: 29D0; + 245760 bytes downloaded
[22:04:05] Initial: AF1F; + 256000 bytes downloaded
[22:04:05] Initial: 05BE; + 266240 bytes downloaded
[22:04:06] Initial: D366; + 276480 bytes downloaded
[22:04:06] Initial: A52F; + 286720 bytes downloaded
[22:04:06] Initial: 1E70; + 296960 bytes downloaded
[22:04:07] Initial: 7229; + 307200 bytes downloaded
[22:04:07] Initial: A7F6; + 317440 bytes downloaded
[22:04:08] Initial: 44C2; + 327680 bytes downloaded
[22:04:08] Initial: A72B; + 337920 bytes downloaded
[22:04:08] Initial: 9C10; + 348160 bytes downloaded
[22:04:09] Initial: 891C; + 358400 bytes downloaded
[22:04:09] Initial: F143; + 368640 bytes downloaded
[22:04:09] Initial: 795C; + 378880 bytes downloaded
[22:04:10] Initial: 8C2B; + 389120 bytes downloaded
[22:04:10] Initial: FC93; + 399360 bytes downloaded
[22:04:10] Initial: F24B; + 409600 bytes downloaded
[22:04:10] Initial: 9D83; + 419840 bytes downloaded
[22:04:11] Initial: 0F67; + 430080 bytes downloaded
[22:04:11] Initial: FB4A; + 440320 bytes downloaded
[22:04:11] Initial: F331; + 450560 bytes downloaded
[22:04:11] Initial: 5BF6; + 460800 bytes downloaded
[22:04:11] Initial: 240B; + 471040 bytes downloaded
[22:04:12] Initial: 47D4; + 481280 bytes downloaded
[22:04:12] Initial: 3AB2; + 491520 bytes downloaded
[22:04:12] Initial: 0F84; + 501760 bytes downloaded
[22:04:12] Initial: CA7A; + 512000 bytes downloaded
[22:04:13] Initial: 3B69; + 522240 bytes downloaded
[22:04:13] Initial: F0AA; + 532480 bytes downloaded
[22:04:13] Initial: 1B36; + 542720 bytes downloaded
[22:04:13] Initial: BCE4; + 552960 bytes downloaded
[22:04:14] Initial: 9BEA; + 563200 bytes downloaded
[22:04:14] Initial: E168; + 573440 bytes downloaded
[22:04:14] Initial: C3A1; + 583680 bytes downloaded
[22:04:14] Initial: 5920; + 593920 bytes downloaded
[22:04:14] Initial: 1D0F; + 604160 bytes downloaded
[22:04:15] Initial: E779; + 614400 bytes downloaded
[22:04:15] Initial: E6CE; + 624640 bytes downloaded
[22:04:15] Initial: 9E24; + 634880 bytes downloaded
[22:04:15] Initial: EB69; + 645120 bytes downloaded
[22:04:15] Initial: 38FC; + 655360 bytes downloaded
[22:04:16] Initial: 6F35; + 665600 bytes downloaded
[22:04:16] Initial: 8C15; + 675840 bytes downloaded
[22:04:16] Initial: 21FE; + 686080 bytes downloaded
[22:04:16] Initial: B05C; + 696320 bytes downloaded
[22:04:16] Initial: 1BD5; + 706560 bytes downloaded
[22:04:17] Initial: FD2D; + 716800 bytes downloaded
[22:04:17] Initial: 2210; + 727040 bytes downloaded
[22:04:17] Initial: BC67; + 737280 bytes downloaded
[22:04:17] Initial: C396; + 747520 bytes downloaded
[22:04:17] Initial: A39D; + 757760 bytes downloaded
[22:04:17] Initial: D988; + 768000 bytes downloaded
[22:04:18] Initial: 7358; + 778240 bytes downloaded
[22:04:18] Initial: 3F63; + 788480 bytes downloaded
[22:04:18] Initial: 7C28; + 798720 bytes downloaded
[22:04:19] Initial: A4B3; + 808960 bytes downloaded
[22:04:19] Initial: 9978; + 819200 bytes downloaded
[22:04:19] Initial: C1AC; + 825633 bytes downloaded
[22:04:20] Verifying core Core_78.fah...
[22:04:20] Signature is VALID
[22:04:20]
[22:04:20] Trying to unzip core FahCore_78.exe
[22:04:20] Decompressed FahCore_78.exe (2338816 bytes) successfully
[22:04:20] + Core successfully engaged
[22:04:25]
[22:04:25] + Processing work unit
[22:04:25] Core required: FahCore_78.exe
[22:04:25] Core found.
[22:04:25] Working on Unit 01 [December 29 22:04:25]
[22:04:25] + Working ...
[22:04:25] - Calling 'FahCore_78.exe -dir work/ -suffix 01 -checkpoint 15 -service -forceasm -verbose -lifeline 3568 -version 502'
[22:04:25]
[22:04:25] *------------------------------*
[22:04:25] Folding@Home Gromacs Core
[22:04:25] Version 1.90 (March 8, 2006)
[22:04:25]
[22:04:25] Preparing to commence simulation
[22:04:25] - Assembly optimizations manually forced on.
[22:04:25] - Not checking prior termination.
[22:04:30] - Expanded 3059248 -> 16578197 (decompressed 541.9 percent)
[22:04:30] - Error: Bad work unit. Digital signatures don't match
[22:04:30] Error: Could not open work file
[22:04:30]
[22:04:30] Folding@home Core Shutdown: FILE_IO_ERROR
[22:04:34] CoreStatus = 75 (117)
[22:04:34] Error opening or reading from a file.
[22:04:34] Deleting current work unit & continuing...
[22:04:38] Trying to send all finished work units
[22:04:38] + No unsent completed units remaining.
[22:04:38] - Preparing to get new work unit...
[22:04:38] + Attempting to get work packet
[22:04:38] - Will indicate memory of 2047 MB.
[22:04:38] - Connecting to assignment server
[22:04:38] Connecting to http://assign.stanford.edu:8080/
[22:04:39] Posted data.
[22:04:39] Initial: 41AB; - Successful: assigned to (171.65.103.162).
[22:04:39] + News From Folding@Home: Welcome to Folding@Home
[22:04:39] Loaded queue successfully.
[22:04:39] Connecting to http://171.65.103.162:8080/
[22:04:39] - Couldn't send HTTP request to server
[22:04:39] (Got status 503)
[22:04:39] + Could not connect to Work Server
[22:04:39] - Error: Attempt #1 to get work failed, and no other work to do.
Waiting before retry.
[22:04:49] + Attempting to get work packet
[22:04:49] - Will indicate memory of 2047 MB.
[22:04:49] - Connecting to assignment server
[22:04:49] Connecting to http://assign.stanford.edu:8080/
[22:04:50] Posted data.
[22:04:50] Initial: 41AB; - Successful: assigned to (171.65.103.162).
[22:04:50] + News From Folding@Home: Welcome to Folding@Home
[22:04:50] Loaded queue successfully.
[22:04:50] Connecting to http://171.65.103.162:8080/
[22:04:58] Posted data.
[22:04:58] Initial: 0000; - Receiving payload (expected size: 3053025)
[22:06:41] - Downloaded at ~28 kB/s
[22:06:41] - Averaged speed for that direction ~23 kB/s
[22:06:41] + Received work.
[22:06:41] + Closed connections
[22:06:46]
[22:06:46] + Processing work unit
[22:06:46] Core required: FahCore_78.exe
[22:06:46] Core found.
[22:06:46] Working on Unit 02 [December 29 22:06:46]
[22:06:46] + Working ...
[22:06:46] - Calling 'FahCore_78.exe -dir work/ -suffix 02 -checkpoint 15 -service -forceasm -verbose -lifeline 3568 -version 502'
[22:06:46]
[22:06:46] *------------------------------*
[22:06:46] Folding@Home Gromacs Core
[22:06:46] Version 1.90 (March 8, 2006)
[22:06:46]
[22:06:46] Preparing to commence simulation
[22:06:46] - Assembly optimizations manually forced on.
[22:06:46] - Not checking prior termination.
[22:06:51] - Expanded 3052513 -> 16578209 (decompressed 543.1 percent)
[22:06:52] - Starting from initial work packet
[22:06:52]
[22:06:52] Project: 2418 (Run 35, Clone 27, Gen 9)
[22:06:52]
[22:06:52] Assembly optimizations on if available.
[22:06:52] Entering M.D.
[22:07:01] Protein: p2418_Ribo_Mg
[22:07:01]
[22:07:01] Writing local files
[22:07:06] Extra SSE boost OK.
[22:07:07] Writing local files
[22:07:08] Completed 0 out of 250000 steps (0)
[22:22:09] Timered checkpoint triggered.
[22:37:10] Timered checkpoint triggered.
[22:52:12] Timered checkpoint triggered.
[22:56:43] Writing local files
[22:56:43] Completed 2500 out of 250000 steps (1)
--- Opening Log file [December 29 23:02:02]
Warning:
use of the flag.
[23:02:02] - Ask before connecting: No
[23:02:02] - User name: SkuToV (Team 32)
[23:02:02] - User ID: 644E3621260A0E40
[23:02:02] - Machine ID: 1
[23:02:02]
[23:02:02] Loaded queue successfully.
[23:02:02] + Benchmarking ...
[23:02:04] The benchmark result is 3640
[23:02:04]
[23:02:04] + Processing work unit
[23:02:04] - Autosending finished units...
[23:02:04] Core required: FahCore_78.exe
[23:02:04] Trying to send all finished work units
[23:02:04] + No unsent completed units remaining.
[23:02:04] Core found.
[23:02:04] - Autosend completed
[23:02:04] Working on Unit 02 [December 29 23:02:04]
[23:02:04] + Working ...
[23:02:04] - Calling 'FahCore_78.exe -dir work/ -suffix 02 -checkpoint 15 -service -forceasm -verbose -lifeline 1372 -version 502'
[23:02:04]
[23:02:04] *------------------------------*
[23:02:04] Folding@Home Gromacs Core
[23:02:04] Version 1.90 (March 8, 2006)
[23:02:04]
[23:02:04] Preparing to commence simulation
[23:02:04] - Assembly optimizations manually forced on.
[23:02:04] - Not checking prior termination.
[23:02:11] - Expanded 3052513 -> 16578209 (decompressed 543.1 percent)
[23:02:12]
[23:02:12] Project: 2418 (Run 35, Clone 27, Gen 9)
[23:02:12]
[23:02:12] Assembly optimizations on if available.
[23:02:12] Entering M.D.
[23:02:36] (Starting from checkpoint)
[23:02:36] Protein: p2418_Ribo_Mg
[23:02:36]
[23:02:36] Writing local files
[23:02:36] Completed 2500 out of 250000 steps (1)
[23:02:41] Extra SSE boost OK.
[23:17:45] Timered checkpoint triggered.
--- Opening Log file [December 29 23:28:49]
Warning:
use of the flag.
[23:28:49] - Ask before connecting: No
[23:28:49] - User name: SkuToV (Team 32)
[23:28:49] - User ID: 644E3621260A0E40
[23:28:49] - Machine ID: 1
[23:28:49]
[23:28:49] Loaded queue successfully.
[23:28:49] + Benchmarking ...
[23:28:52] The benchmark result is 3084
[23:28:52]
[23:28:52] + Processing work unit
[23:28:52] Core required: FahCore_78.exe
[23:28:52] - Autosending finished units...
[23:28:52] Trying to send all finished work units
[23:28:52] + No unsent completed units remaining.
[23:28:52] - Autosend completed
[23:28:52] Core found.
[23:28:52] Working on Unit 02 [December 29 23:28:52]
[23:28:52] + Working ...
[23:28:52] - Calling 'FahCore_78.exe -dir work/ -suffix 02 -checkpoint 15 -service -forceasm -verbose -lifeline 968 -version 502'
[23:28:52]
[23:28:52] *------------------------------*
[23:28:52] Folding@Home Gromacs Core
[23:28:52] Version 1.90 (March 8, 2006)
[23:28:52]
[23:28:52] Preparing to commence simulation
[23:28:52] - Ensuring status. Please wait.
[23:29:09] - Assembly optimizations manually forced on.
[23:29:09] - Not checking prior termination.
--- Opening Log file [December 29 23:33:09]
Warning:
use of the flag.
[23:33:09] - Ask before connecting: No
[23:33:09] - User name: SkuToV (Team 32)
[23:33:09] - User ID: 644E3621260A0E40
[23:33:09] - Machine ID: 1
[23:33:09]
[23:33:09] Loaded queue successfully.
[23:33:09] + Benchmarking ...
[23:33:11] The benchmark result is 3688
[23:33:11]
[23:33:11] - Autosending finished units...
[23:33:11] Trying to send all finished work units
[23:33:11] + No unsent completed units remaining.
[23:33:11] + Processing work unit
[23:33:11] Core required: FahCore_78.exe
[23:33:11] - Autosend completed
[23:33:11] Core found.
[23:33:11] Working on Unit 02 [December 29 23:33:11]
[23:33:11] + Working ...
[23:33:11] - Calling 'FahCore_78.exe -dir work/ -suffix 02 -checkpoint 15 -service -forceasm -verbose -lifeline 2024 -version 502'
[23:33:13]
[23:33:13] *------------------------------*
[23:33:13] Folding@Home Gromacs Core
[23:33:13] Version 1.90 (March 8, 2006)
[23:33:13]
[23:33:13] Preparing to commence simulation
[23:33:13] - Ensuring status. Please wait.
[23:33:30] - Assembly optimizations manually forced on.
[23:33:30] - Not checking prior termination.
[23:33:38] - Expanded 3052513 -> 16578209 (decompressed 543.1 percent)
[23:33:40] - Error: Bad work unit. Digital signatures don't match
[23:33:40] Error: Could not open work file
[23:33:40]
[23:33:40] Folding@home Core Shutdown: FILE_IO_ERROR
[23:33:44] CoreStatus = 75 (117)
[23:33:44] Error opening or reading from a file.
[23:33:44] Deleting current work unit & continuing...
[23:33:49] Trying to send all finished work units
[23:33:49] + No unsent completed units remaining.
[23:33:49] - Preparing to get new work unit...
[23:33:49] + Attempting to get work packet
[23:33:49] - Will indicate memory of 2047 MB.
[23:33:49] - Connecting to assignment server
[23:33:49] Connecting to http://assign.stanford.edu:8080/
[23:33:54] Posted data.
[23:33:54] Initial: 41AB; - Successful: assigned to (171.65.103.162).
[23:33:54] + News From Folding@Home: Welcome to Folding@Home
[23:33:54] Loaded queue successfully.
[23:33:54] Connecting to http://171.65.103.162:8080/
[23:33:55] - Couldn't send HTTP request to server
[23:33:55] + Could not connect to Work Server
[23:33:55] - Error: Attempt #1 to get work failed, and no other work to do.
[23:34:08] + Attempting to get work packet
[23:34:08] - Will indicate memory of 2047 MB.
[23:34:08] - Connecting to assignment server
[23:34:08] Connecting to http://assign.stanford.edu:8080/
[23:34:09] Posted data.
[23:34:09] Initial: 41AB; - Successful: assigned to (171.65.103.162).
[23:34:09] + News From Folding@Home: Welcome to Folding@Home
[23:34:09] Loaded queue successfully.
[23:34:09] Connecting to http://171.65.103.162:8080/
[23:34:09] - Couldn't send HTTP request to server
[23:34:09] (Got status 503)
[23:34:09] + Could not connect to Work Server
[23:34:09] - Error: Attempt #2 to get work failed, and no other work to do.
[23:34:22] + Attempting to get work packet
[23:34:22] - Will indicate memory of 2047 MB.
[23:34:22] - Connecting to assignment server
[23:34:22] Connecting to http://assign.stanford.edu:8080/
[23:34:23] Posted data.
[23:34:23] Initial: 41AB; - Successful: assigned to (171.65.103.162).
[23:34:23] + News From Folding@Home: Welcome to Folding@Home
[23:34:23] Loaded queue successfully.
[23:34:23] Connecting to http://171.65.103.162:8080/
[23:34:29] Posted data.
[23:34:29] Initial: 0000; - Receiving payload (expected size: 3064884)
[23:35:17] - Downloaded at ~62 kB/s
[23:35:17] - Averaged speed for that direction ~36 kB/s
[23:35:17] + Received work.
[23:35:17] + Closed connections
[23:35:22]
[23:35:22] + Processing work unit
[23:35:22] Core required: FahCore_78.exe
[23:35:22] Core found.
[23:35:22] Working on Unit 03 [December 29 23:35:22]
[23:35:22] + Working ...
[23:35:22] - Calling 'FahCore_78.exe -dir work/ -suffix 03 -checkpoint 15 -service -forceasm -verbose -lifeline 2024 -version 502'
[23:35:22]
[23:35:22] *------------------------------*
[23:35:22] Folding@Home Gromacs Core
[23:35:22] Version 1.90 (March 8, 2006)
[23:35:22]
[23:35:22] Preparing to commence simulation
[23:35:22] - Assembly optimizations manually forced on.
[23:35:22] - Not checking prior termination.
[23:35:27] - Expanded 3064372 -> 16578185 (decompressed 540.9 percent)
[23:35:28] - Error: Bad work unit. Digital signatures don't match
[23:35:28] Error: Could not open work file
[23:35:28]
[23:35:28] Folding@home Core Shutdown: FILE_IO_ERROR
[23:35:30] CoreStatus = 75 (117)
[23:35:30] Error opening or reading from a file.
[23:35:30] Deleting current work unit & continuing...
[23:35:34] Trying to send all finished work units
[23:35:34] + No unsent completed units remaining.
[23:35:34] - Preparing to get new work unit...
[23:35:34] + Attempting to get work packet
[23:35:34] - Will indicate memory of 2047 MB.
[23:35:34] - Connecting to assignment server
[23:35:34] Connecting to http://assign.stanford.edu:8080/
[23:35:35] Posted data.
[23:35:35] Initial: 41AB; - Successful: assigned to (171.65.103.162).
[23:35:35] + News From Folding@Home: Welcome to Folding@Home
[23:35:35] Loaded queue successfully.
[23:35:35] Connecting to http://171.65.103.162:8080/
[23:35:35] - Couldn't send HTTP request to server
[23:35:35] (Got status 503)
[23:35:35] + Could not connect to Work Server
[23:35:35] - Error: Attempt #1 to get work failed, and no other work to do.
[23:35:54] + Attempting to get work packet
[23:35:54] - Will indicate memory of 2047 MB.
[23:35:54] - Connecting to assignment server
[23:35:54] Connecting to http://assign.stanford.edu:8080/
[23:35:55] Posted data.
[23:35:55] Initial: 41AB; - Successful: assigned to (171.65.103.162).
[23:35:55] + News From Folding@Home: Welcome to Folding@Home
[23:35:55] Loaded queue successfully.
[23:35:55] Connecting to http://171.65.103.162:8080/
[23:35:55] - Couldn't send HTTP request to server
[23:35:55] (Got status 503)
[23:35:55] + Could not connect to Work Server
[23:35:55] - Error: Attempt #2 to get work failed, and no other work to do.
[23:36:16] + Attempting to get work packet
[23:36:16] - Will indicate memory of 2047 MB.
[23:36:16] - Connecting to assignment server
[23:36:16] Connecting to http://assign.stanford.edu:8080/
[23:36:16] Posted data.
[23:36:16] Initial: 41AB; - Successful: assigned to (171.65.103.162).
[23:36:16] + News From Folding@Home: Welcome to Folding@Home
[23:36:17] Loaded queue successfully.
[23:36:17] Connecting to http://171.65.103.162:8080/
[23:36:17] - Couldn't send HTTP request to server
[23:36:17] (Got status 503)
[23:36:17] + Could not connect to Work Server
[23:36:17] - Error: Attempt #3 to get work failed, and no other work to do.
--- Opening Log file [December 29 23:38:52]
Warning:
use of the flag.
[23:38:52] - Ask before connecting: No
[23:38:52] - User name: SkuToV (Team 32)
[23:38:52] - User ID: 644E3621260A0E40
[23:38:52] - Machine ID: 1
[23:38:52]
[23:38:52] Loaded queue successfully.
[23:38:52] + Benchmarking ...
[23:38:56] The benchmark result is 4096
[23:38:56] - Preparing to get new work unit...
[23:38:56] - Autosending finished units...
[23:38:56] Trying to send all finished work units
[23:38:56] + No unsent completed units remaining.
[23:38:56] - Autosend completed
[23:38:56] + Attempting to get work packet
[23:38:56] - Will indicate memory of 2047 MB.
[23:38:56] - Connecting to assignment server
[23:38:56] Connecting to http://assign.stanford.edu:8080/
[23:38:58] Posted data.
[23:38:58] Initial: 41AB; - Successful: assigned to (171.65.103.162).
[23:38:58] + News From Folding@Home: Welcome to Folding@Home
[23:38:58] Loaded queue successfully.
[23:38:58] Connecting to http://171.65.103.162:8080/
[23:38:59] - Couldn't send HTTP request to server
[23:38:59] (Got status 503)
[23:38:59] + Could not connect to Work Server
[23:38:59] - Error: Attempt #1 to get work failed, and no other work to do.
[23:39:11] + Attempting to get work packet
[23:39:11] - Will indicate memory of 2047 MB.
[23:39:11] - Connecting to assignment server
[23:39:11] Connecting to http://assign.stanford.edu:8080/
[23:39:12] Posted data.
[23:39:12] Initial: 41AB; - Successful: assigned to (171.65.103.162).
[23:39:12] + News From Folding@Home: Welcome to Folding@Home
[23:39:12] Loaded queue successfully.
[23:39:12] Connecting to http://171.65.103.162:8080/
[23:39:12] - Couldn't send HTTP request to server
[23:39:12] + Could not connect to Work Server
[23:39:12] - Error: Attempt #2 to get work failed, and no other work to do.
[23:39:35] + Attempting to get work packet
[23:39:35] - Will indicate memory of 2047 MB.
[23:39:35] - Connecting to assignment server
[23:39:35] Connecting to http://assign.stanford.edu:8080/
[23:39:36] Posted data.
[23:39:36] Initial: 41AB; - Successful: assigned to (171.65.103.162).
[23:39:36] + News From Folding@Home: Welcome to Folding@Home
[23:39:37] Loaded queue successfully.
[23:39:37] Connecting to http://171.65.103.162:8080/
[23:39:37] - Couldn't send HTTP request to server
[23:39:37] (Got status 503)
[23:39:37] + Could not connect to Work Server
[23:39:37] - Error: Attempt #3 to get work failed, and no other work to do.
[23:40:04] + Attempting to get work packet
[23:40:04] - Will indicate memory of 2047 MB.
[23:40:04] - Connecting to assignment server
[23:40:04] Connecting to http://assign.stanford.edu:8080/
[23:40:05] Posted data.
[23:40:05] Initial: 41AB; - Successful: assigned to (171.65.103.162).
[23:40:05] + News From Folding@Home: Welcome to Folding@Home
[23:40:05] Loaded queue successfully.
[23:40:05] Connecting to http://171.65.103.162:8080/
[23:40:06] - Couldn't send HTTP request to server
[23:40:06] (Got status 503)
[23:40:06] + Could not connect to Work Server
[23:40:06] - Error: Attempt #4 to get work failed, and no other work to do.
[23:40:58] + Attempting to get work packet
[23:40:58] - Will indicate memory of 2047 MB.
[23:40:58] - Connecting to assignment server
[23:40:58] Connecting to http://assign.stanford.edu:8080/
[23:40:59] Posted data.
[23:40:59] Initial: 41AB; - Successful: assigned to (171.65.103.162).
[23:40:59] + News From Folding@Home: Welcome to Folding@Home
[23:40:59] Loaded queue successfully.
[23:40:59] Connecting to http://171.65.103.162:8080/
[23:41:00] - Couldn't send HTTP request to server
[23:41:00] (Got status 503)
[23:41:00] + Could not connect to Work Server
[23:41:00] - Error: Attempt #5 to get work failed, and no other work to do.
[23:42:31] + Attempting to get work packet
[23:42:31] - Will indicate memory of 2047 MB.
[23:42:31] - Connecting to assignment server
[23:42:31] Connecting to http://assign.stanford.edu:8080/
[23:42:32] Posted data.
[23:42:32] Initial: 41AB; - Successful: assigned to (171.65.103.162).
[23:42:32] + News From Folding@Home: Welcome to Folding@Home
[23:42:32] Loaded queue successfully.
[23:42:32] Connecting to http://171.65.103.162:8080/
[23:42:33] - Couldn't send HTTP request to server
[23:42:33] + Could not connect to Work Server
[23:42:33] - Error: Attempt #6 to get work failed, and no other work to do.
[23:45:13] + Attempting to get work packet
[23:45:13] - Will indicate memory of 2047 MB.
[23:45:13] - Connecting to assignment server
[23:45:13] Connecting to http://assign.stanford.edu:8080/
[23:45:18] Posted data.
[23:45:18] Initial: 41AB; - Successful: assigned to (171.65.103.162).
[23:45:18] + News From Folding@Home: Welcome to Folding@Home
[23:45:18] Loaded queue successfully.
[23:45:18] Connecting to http://171.65.103.162:8080/
[23:45:19] - Couldn't send HTTP request to server
[23:45:19] (Got status 503)
[23:45:19] + Could not connect to Work Server
[23:45:19] - Error: Attempt #7 to get work failed, and no other work to do.
[23:50:49] + Attempting to get work packet
[23:50:49] - Will indicate memory of 2047 MB.
[23:50:49] - Connecting to assignment server
[23:50:49] Connecting to http://assign.stanford.edu:8080/
[23:50:50] Posted data.
[23:50:50] Initial: 41AB; - Successful: assigned to (171.65.103.160).
[23:50:50] + News From Folding@Home: Welcome to Folding@Home
[23:50:51] Loaded queue successfully.
[23:50:51] Connecting to http://171.65.103.160:8080/
[23:50:52] Posted data.
[23:50:52] Initial: 0000; - Receiving payload (expected size: 399470)
[23:51:01] - Downloaded at ~43 kB/s
[23:51:01] - Averaged speed for that direction ~37 kB/s
[23:51:01] + Received work.
[23:51:01] + Closed connections
[23:51:01]
[23:51:01] + Processing work unit
[23:51:01] Core required: FahCore_78.exe
[23:51:01] Core found.
[23:51:01] Working on Unit 04 [December 29 23:51:01]
[23:51:01] + Working ...
[23:51:01] - Calling 'FahCore_78.exe -dir work/ -suffix 04 -checkpoint 15 -service -forceasm -verbose -lifeline 140 -version 502'
[23:51:02]
[23:51:02] *------------------------------*
[23:51:02] Folding@Home Gromacs Core
[23:51:02] Version 1.90 (March 8, 2006)
[23:51:02]
[23:51:02] Preparing to commence simulation
[23:51:02] - Assembly optimizations manually forced on.
[23:51:02] - Not checking prior termination.
[23:51:02] - Expanded 398958 -> 2038389 (decompressed 510.9 percent)
[23:51:02] - Starting from initial work packet
[23:51:02]
[23:51:02] Project: 3404 (Run 5, Clone 726, Gen 28)
[23:51:02]
[23:51:02] Assembly optimizations on if available.
[23:51:02] Entering M.D.
[23:51:09] Protein: p3404_dpdp-ii TIP3P ff99
[23:51:09]
[23:51:09] Writing local files
[23:51:09] Extra SSE boost OK.
[23:51:09] Completed 0 out of 4000000 steps (0)
--- Opening Log file [December 30 00:02:19]
Warning:
use of the flag.
[00:02:19] - Ask before connecting: No
[00:02:19] - User name: SkuToV (Team 32)
[00:02:19] - User ID: 644E3621260A0E40
[00:02:19] - Machine ID: 1
[00:02:19]
[00:02:19] Loaded queue successfully.
[00:02:19] + Benchmarking ...
[00:02:22] The benchmark result is 2380
[00:02:22]
[00:02:22] - Autosending finished units...
[00:02:22] Trying to send all finished work units
[00:02:22] + No unsent completed units remaining.
[00:02:22] - Autosend completed
[00:02:22] + Processing work unit
[00:02:22] Core required: FahCore_78.exe
[00:02:22] Core found.
[00:02:22] Working on Unit 04 [December 30 00:02:22]
[00:02:22] + Working ...
[00:02:22] - Calling 'FahCore_78.exe -dir work/ -suffix 04 -checkpoint 15 -service -forceasm -verbose -lifeline 3912 -version 502'
[00:02:22]
[00:02:22] *------------------------------*
[00:02:22] Folding@Home Gromacs Core
[00:02:22] Version 1.90 (March 8, 2006)
[00:02:22]
[00:02:22] Preparing to commence simulation
[00:02:22] - Assembly optimizations manually forced on.
[00:02:22] - Not checking prior termination.
[00:02:23] - Expanded 398958 -> 2038389 (decompressed 510.9 percent)
[00:02:23]
[00:02:23] Project: 3404 (Run 5, Clone 726, Gen 28)
[00:02:23]
[00:02:23] Assembly optimizations on if available.
[00:02:23] Entering M.D.
[00:02:44] (Starting from checkpoint)
[00:02:44] Protein: p3404_dpdp-ii TIP3P ff99
[00:02:44]
[00:02:44] Writing local files
[00:02:44] Extra SSE boost OK.
[00:02:44] Completed 0 out of 4000000 steps (0)
[00:17:45] Timered checkpoint triggered.
--- Opening Log file [December 30 01:53:22]
Warning:
use of the flag.
[01:53:22] - Ask before connecting: No
[01:53:22] - User name: SkuToV (Team 32)
[01:53:22] - User ID: 644E3621260A0E40
[01:53:22] - Machine ID: 1
[01:53:22]
[01:53:22] Loaded queue successfully.
[01:53:22] + Benchmarking ...
[01:53:24] The benchmark result is 3276
[01:53:24]
[01:53:24] + Processing work unit
[01:53:24] - Autosending finished units...
[01:53:24] Core required: FahCore_78.exe
[01:53:24] Trying to send all finished work units
[01:53:24] + No unsent completed units remaining.
[01:53:24] Core found.
[01:53:24] - Autosend completed
[01:53:24] Working on Unit 04 [December 30 01:53:24]
[01:53:24] + Working ...
[01:53:24] - Calling 'FahCore_78.exe -dir work/ -suffix 04 -checkpoint 15 -service -forceasm -verbose -lifeline 2664 -version 502'
[01:53:25]
[01:53:25] *------------------------------*
[01:53:25] Folding@Home Gromacs Core
[01:53:25] Version 1.90 (March 8, 2006)
[01:53:25]
[01:53:25] Preparing to commence simulation
[01:53:25] - Assembly optimizations manually forced on.
[01:53:25] - Not checking prior termination.
[01:53:25] - Expanded 398958 -> 2038389 (decompressed 510.9 percent)
[01:53:25]
[01:53:25] Project: 3404 (Run 5, Clone 726, Gen 28)
[01:53:25]
[01:53:26] Assembly optimizations on if available.
[01:53:26] Entering M.D.
[01:53:46] (Starting from checkpoint)
[01:53:46] Protein: p3404_dpdp-ii TIP3P ff99
[01:53:46]
[01:53:46] Writing local files
[01:53:46] Completed 15835 out of 4000000 steps (0)
[01:53:46] Extra SSE boost OK.
[02:08:45] Timered checkpoint triggered.
[02:16:47] Writing local files
[02:16:47] Completed 40000 out of 4000000 steps (1)
[02:31:47] Timered checkpoint triggered.
[02:46:47] Timered checkpoint triggered.
[02:53:14] Writing local files
[02:53:14] Completed 80000 out of 4000000 steps (2)
[03:08:14] Timered checkpoint triggered.
[03:23:14] Timered checkpoint triggered.
[03:29:37] Writing local files
[03:29:37] Completed 120000 out of 4000000 steps (3)
[03:44:37] Timered checkpoint triggered.
[03:59:37] Timered checkpoint triggered.
[04:05:50] Writing local files
[04:05:50] Completed 160000 out of 4000000 steps (4)
[04:20:50] Timered checkpoint triggered.
[04:35:50] Timered checkpoint triggered.
[04:42:04] Writing local files
[04:42:04] Completed 200000 out of 4000000 steps (5)
[04:57:04] Timered checkpoint triggered.
[05:12:04] Timered checkpoint triggered.
[05:18:21] Writing local files
[05:18:22] Completed 240000 out of 4000000 steps (6)
[05:33:21] Timered checkpoint triggered.
[05:48:21] Timered checkpoint triggered.
[05:54:44] Writing local files
[05:54:44] Completed 280000 out of 4000000 steps (7)
[06:09:44] Timered checkpoint triggered.
[06:24:44] Timered checkpoint triggered.
[06:30:54] Writing local files
[06:30:54] Completed 320000 out of 4000000 steps (8)
[06:45:54] Timered checkpoint triggered.
[07:00:54] Timered checkpoint triggered.
[07:07:07] Writing local files
[07:07:07] Completed 360000 out of 4000000 steps (9)
[07:22:08] Timered checkpoint triggered.
[07:37:08] Timered checkpoint triggered.
[07:43:25] Writing local files
[07:43:25] Completed 400000 out of 4000000 steps (10)
[07:53:24] - Autosending finished units...
[07:53:24] Trying to send all finished work units
[07:53:24] + No unsent completed units remaining.
[07:53:24] - Autosend completed
[07:58:26] Timered checkpoint triggered.
[08:13:26] Timered checkpoint triggered.
[08:19:37] Writing local files
[08:19:37] Completed 440000 out of 4000000 steps (11)
[08:34:38] Timered checkpoint triggered.
[08:49:38] Timered checkpoint triggered.
[08:55:55] Writing local files
[08:55:55] Completed 480000 out of 4000000 steps (12)
[09:10:56] Timered checkpoint triggered.
[09:25:56] Timered checkpoint triggered.
[09:32:15] Writing local files
[09:32:15] Completed 520000 out of 4000000 steps (13)
[09:47:14] Timered checkpoint triggered.
[10:02:14] Timered checkpoint triggered.
[10:08:41] Writing local files
[10:08:41] Completed 560000 out of 4000000 steps (14)
[10:23:42] Timered checkpoint triggered.
[10:38:41] Timered checkpoint triggered.
[10:44:48] Writing local files
[10:44:48] Completed 600000 out of 4000000 steps (15)
[10:59:48] Timered checkpoint triggered.
[11:14:48] Timered checkpoint triggered.
--- Opening Log file [December 30 11:38:46]
Warning:
use of the flag.
[11:38:46] - Ask before connecting: No
[11:38:46] - User name: SkuToV (Team 32)
[11:38:46] - User ID: 644E3621260A0E40
[11:38:46] - Machine ID: 1
[11:38:46]
[11:38:46] Loaded queue successfully.
[11:38:46] + Benchmarking ...
[11:38:49] The benchmark result is 3232
[11:38:49]
[11:38:49] + Processing work unit
[11:38:49] - Autosending finished units...
[11:38:49] Core required: FahCore_78.exe
[11:38:49] Trying to send all finished work units
[11:38:49] + No unsent completed units remaining.
[11:38:49] - Autosend completed
[11:38:49] Core found.
[11:38:49] Working on Unit 04 [December 30 11:38:49]
[11:38:49] + Working ...
[11:38:49] - Calling 'FahCore_78.exe -dir work/ -suffix 04 -checkpoint 15 -service -forceasm -verbose -lifeline 3396 -version 502'
[11:38:49]
[11:38:49] *------------------------------*
[11:38:49] Folding@Home Gromacs Core
[11:38:49] Version 1.90 (March 8, 2006)
[11:38:49]
[11:38:49] Preparing to commence simulation
[11:38:49] - Assembly optimizations manually forced on.
[11:38:49] - Not checking prior termination.
[11:38:49] - Expanded 398958 -> 2038389 (decompressed 510.9 percent)
[11:38:50]
[11:38:50] Project: 3404 (Run 5, Clone 726, Gen 28)
[11:38:50]
[11:38:50] Assembly optimizations on if available.
[11:38:50] Entering M.D.
[11:39:10] (Starting from checkpoint)
[11:39:10] Protein: p3404_dpdp-ii TIP3P ff99
[11:39:10]
[11:39:10] Writing local files
[11:39:10] Completed 631019 out of 4000000 steps (16)
[11:39:10] Extra SSE boost OK.
--- Opening Log file [December 30 11:41:37]
Warning:
use of the flag.
[11:41:37] - Ask before connecting: No
[11:41:37] - User name: SkuToV (Team 32)
[11:41:37] - User ID: 644E3621260A0E40
[11:41:37] - Machine ID: 1
[11:41:37]
[11:41:37] Loaded queue successfully.
[11:41:37] + Benchmarking ...
[11:41:40] The benchmark result is 3492
[11:41:40]
[11:41:40] + Processing work unit
[11:41:40] Core required: FahCore_78.exe
[11:41:40] - Autosending finished units...
[11:41:40] Trying to send all finished work units
[11:41:40] Core found.
[11:41:40] + No unsent completed units remaining.
[11:41:40] - Autosend completed
[11:41:40] Working on Unit 04 [December 30 11:41:40]
[11:41:40] + Working ...
[11:41:40] - Calling 'FahCore_78.exe -dir work/ -suffix 04 -checkpoint 15 -service -forceasm -verbose -lifeline 2200 -version 502'
[11:41:40] Client no longer detected. Shutting down core
[11:41:50]
[11:41:50] Folding@home Core Shutdown: CLIENT_DIED
[11:51:16] s (16)
[12:06:15] Timered checkpoint triggered.
--- Opening Log file [December 30 12:12:36]
Warning:
use of the flag.
[12:12:36] - Ask before connecting: No
[12:12:36] - User name: SkuToV (Team 32)
[12:12:36] - User ID: 644E3621260A0E40
[12:12:36] - Machine ID: 1
[12:12:36]
[12:12:36] Loaded queue successfully.
[12:12:36] + Benchmarking ...
[12:12:39] The benchmark result is 3640
[12:12:39]
[12:12:39] - Autosending finished units...
[12:12:39] Trying to send all finished work units
[12:12:39] + No unsent completed units remaining.
[12:12:39] - Autosend completed
[12:12:39] + Processing work unit
[12:12:39] Core required: FahCore_78.exe
[12:12:39] Core found.
[12:12:39] Working on Unit 04 [December 30 12:12:39]
[12:12:39] + Working ...
[12:12:39] - Calling 'FahCore_78.exe -dir work/ -suffix 04 -checkpoint 15 -service -forceasm -verbose -lifeline 3768 -version 502'
[12:12:39]
[12:12:39] *------------------------------*
[12:12:39] Folding@Home Gromacs Core
[12:12:39] Version 1.90 (March 8, 2006)
[12:12:39]
[12:12:39] Preparing to commence simulation
[12:12:39] - Assembly optimizations manually forced on.
[12:12:39] - Not checking prior termination.
[12:12:40] - Expanded 398958 -> 2038389 (decompressed 510.9 percent)
[12:12:40]
[12:12:40] Project: 3404 (Run 5, Clone 726, Gen 28)
[12:12:40]
[12:12:40] Assembly optimizations on if available.
[12:12:40] Entering M.D.
[12:13:00] (Starting from checkpoint)
[12:13:00] Protein: p3404_dpdp-ii TIP3P ff99
[12:13:00]
[12:13:00] Writing local files
[12:13:00] Completed 653357 out of 4000000 steps (16)
[12:13:00] Extra SSE boost OK.
and the other one:
Code:
Launch directory: C:\Program Files\FAH\FAH2
Executable: C:\Program Files\FAH\FAH2\FAH502-Console.exe
Warning:
use of the flag.
[11:38:46] - Machine ID: 2
[11:38:46]
[11:38:49] The benchmark result is 3316
[11:38:49]
[11:38:49] Working on Unit 07 [December 30 11:38:49]
[11:38:49] - Calling 'FahCore_78.exe -dir work/ -suffix 07 -checkpoint 15 -service -forceasm -verbose -lifeline 3336 -version 502'
[11:38:49]
[11:38:49]
[11:38:54] - Expanded 3058754 -> 16578189 (decompressed 541.9 percent)
[11:38:54]
[11:38:54] Project: 2417 (Run 28, Clone 91, Gen 15)
[11:38:54]
[11:38:54] Assembly optimizations on if available.
[11:38:54] Entering M.D.
[11:39:18] (Starting from checkpoint)
[11:39:18] Protein: p2417_Ribo_Cl
[11:39:18]
[11:39:18] Writing local files
[11:39:19] Completed 28984 out of 250000 steps (12)
[11:39:24] Extra SSE boost OK.
[11:41:04] Gromacs cannot continue further.
[11:41:04] Going to send back what have done.
[11:41:04] logfile size: 40326
[11:41:04] - Writing 40862 bytes of core data to disk...
[11:41:04] ... Done.
[11:41:04]
[11:41:04] Folding@home Core Shutdown: EARLY_UNIT_END
[11:41:07] CoreStatus = 72 (114)
[11:41:07] Sending work to server
[11:41:07] + Attempting to send results
[11:41:07] - Reading file work/wuresults_07.dat from core
[11:41:07] (Read 40862 bytes from disk)
[11:41:07] Connecting to http://171.65.103.162:8080/
[11:41:11] Posted data.
[11:41:11] Initial: 0000; - Uploaded at ~10 kB/s
[11:41:11] - Averaged speed for that direction ~8 kB/s
[11:41:11] + Results successfully sent
[11:41:11] Thank you for your contribution to Folding@Home.
[11:41:15] Trying to send all finished work units
[11:41:15] + No unsent completed units remaining.
[11:41:15] - Preparing to get new work unit...
[11:41:15] + Attempting to get work packet
[11:41:15] - Will indicate memory of 2047 MB.
[11:41:15] - Connecting to assignment server
[11:41:15] Connecting to http://assign.stanford.edu:8080/
[11:41:16] Posted data.
[11:41:16] Initial: 41AB; - Successful: assigned to (171.65.103.162).
[11:41:16] + News From Folding@Home: Welcome to Folding@Home
[11:41:16] Loaded queue successfully.
[11:41:16] Connecting to http://171.65.103.162:8080/
[11:41:17] - Couldn't send HTTP request to server
[11:41:17] (Got status 503)
[11:41:17] + Could not connect to Work Server
[11:41:17] - Error: Attempt #1 to get work failed, and no other work to do.
[11:41:27] + Attempting to get work packet
[11:41:27] - Will indicate memory of 2047 MB.
[11:41:27] - Connecting to assignment server
[11:41:27] Connecting to http://assign.stanford.edu:8080/
[11:41:27] Posted data.
[11:41:27] Initial: 41AB; - Successful: assigned to (171.65.103.162).
[11:41:27] + News From Folding@Home: Welcome to Folding@Home
[11:41:28] Loaded queue successfully.
[11:41:28] Connecting to http://171.65.103.162:8080/
[11:41:28] - Couldn't send HTTP request to server
[11:41:28] + Could not connect to Work Server
[11:41:28] - Error: Attempt #2 to get work failed, and no other work to do.
Warning:
use of the flag.
[11:41:37] - Machine ID: 2
[11:41:37]
[11:41:40] The benchmark result is 3592
[11:41:40] - Preparing to get new work unit...
[11:41:40] + Attempting to get work packet
[11:41:40] - Will indicate memory of 2047 MB.
[11:41:40] - Connecting to assignment server
[11:41:40] Connecting to http://assign.stanford.edu:8080/
[11:41:40] Posted data.
[11:41:40] Initial: 41AB; - Successful: assigned to (171.65.103.162).
[11:41:40] + News From Folding@Home: Welcome to Folding@Home
[11:41:40] Loaded queue successfully.
[11:41:40] Connecting to http://171.65.103.162:8080/
[11:41:41] - Couldn't send HTTP request to server
[11:41:41] + Could not connect to Work Server
[11:41:41] - Error: Attempt #1 to get work failed, and no other work to do.
[11:41:56] + Attempting to get work packet
[11:41:56] - Will indicate memory of 2047 MB.
[11:41:56] - Connecting to assignment server
[11:41:56] Connecting to http://assign.stanford.edu:8080/
[11:41:56] Posted data.
[11:41:56] Initial: 41AB; - Successful: assigned to (171.65.103.162).
[11:41:56] + News From Folding@Home: Welcome to Folding@Home
[11:41:56] Loaded queue successfully.
[11:41:56] Connecting to http://171.65.103.162:8080/
[11:41:57] - Couldn't send HTTP request to server
[11:41:57] (Got status 503)
[11:41:57] + Could not connect to Work Server
[11:41:57] - Error: Attempt #2 to get work failed, and no other work to do.
[11:42:09] + Attempting to get work packet
[11:42:09] - Will indicate memory of 2047 MB.
[11:42:09] - Connecting to assignment server
[11:42:09] Connecting to http://assign.stanford.edu:8080/
[11:42:10] Posted data.
[11:42:10] Initial: 41AB; - Successful: assigned to (171.65.103.162).
[11:42:10] + News From Folding@Home: Welcome to Folding@Home
[11:42:10] Loaded queue successfully.
[11:42:10] Connecting to http://171.65.103.162:8080/
[11:42:16] Posted data.
[11:42:16] Initial: 0000; - Receiving payload (expected size: 3064302)
[11:42:42] - Downloaded at ~115 kB/s
[11:42:42] - Averaged speed for that direction ~67 kB/s
[11:42:42] + Received work.
[11:42:42] + Closed connections
[11:42:42]
[11:42:42] + Processing work unit
[11:42:42] Core required: FahCore_78.exe
[11:42:42] Core found.
[11:42:42] Working on Unit 08 [December 30 11:42:42]
[11:42:42] + Working ...
[11:42:42] - Calling 'FahCore_78.exe -dir work/ -suffix 08 -checkpoint 15 -service -forceasm -verbose -lifeline 2504 -version 502'
[11:42:42]
[11:42:42] *------------------------------*
[11:42:42] Folding@Home Gromacs Core
[11:42:42] Version 1.90 (March 8, 2006)
[11:42:42]
[11:42:42] Preparing to commence simulation
[11:42:42] - Assembly optimizations manually forced on.
[11:42:42] - Not checking prior termination.
[11:42:49] - Expanded 3063790 -> 16578173 (decompressed 541.1 percent)
[11:42:49] - Starting from initial work packet
[11:42:49]
[11:42:49] Project: 2417 (Run 29, Clone 42, Gen 13)
[11:42:49]
[11:42:49] Assembly optimizations on if available.
[11:42:49] Entering M.D.
[11:42:59] Protein: p2417_Ribo_Cl
[11:42:59]
[11:42:59] Writing local files
[11:43:06] Extra SSE boost OK.
[11:43:07] Writing local files
[11:43:07] Completed 0 out of 250000 steps (0)
[11:58:08] Timered checkpoint triggered.
Warning:
use of the flag.
[12:12:36] - Machine ID: 2
[12:12:36]
[12:12:37] Loaded queue successfully.
[12:12:37] + Benchmarking ...
[12:12:39] The benchmark result is 3588
[12:12:39]
[12:12:39] Working on Unit 08 [December 30 12:12:39]
[12:12:39] - Calling 'FahCore_78.exe -dir work/ -suffix 08 -checkpoint 15 -service -forceasm -verbose -lifeline 2540 -version 502'
[12:12:39]
[12:12:39]
[12:12:44] - Expanded 3063790 -> 16578173 (decompressed 541.1 percent)
[12:12:45]
[12:12:45] Project: 2417 (Run 29, Clone 42, Gen 13)
[12:12:45]
[12:12:46] Assembly optimizations on if available.
[12:12:46] Entering M.D.
[12:13:10] (Starting from checkpoint)
[12:13:10] Protein: p2417_Ribo_Cl
[12:13:10]
[12:13:10] Writing local files
[12:13:10] Completed 722 out of 250000 steps (0)
[12:13:16] Extra SSE boost OK.
