- Apr 1, 2012
- CA
So Im setting up my water loop for the first time-- and have an ocd question. The pump i have is an mcp655 swiftech, which has both 3 pin power and also molex to power the pump. Im currently running a TX750 corsair psu, Crosshair4 mobo, 1100T amd, 16gb vengeance ram 1600mhz, 2x 6870's crossfired-- the pump is out of the ultima kit from swiftech. cpu is seated// ceramique applied to block...etc.
just having ocd about the power management--// do i connect it to the power fan on the mobo? use the molex? OPT fan on mobo...etc--// I need a bit of guidance from the experts as I dont want to fry anything. case is a Haf X.
Also, on the beginners guide it doesnt really mention any cable/power options. And just to clarify... loop is res to pump, pump to rad, rad to cpu, cpu to res? the guide states it really doesnt matter...
thanks in advance
thanks in advance
