- Jun 11, 2014
hi guys ! 1st time here , so i have a question my second gtx 760 just arrived now , i have this PSU http://www.tacens.es/fuentes_de_alimentacion/fuente_de_alimentacion_radixvi750.html , can this psu handle my 2 gtx 760's ?
thank u sir , here is the rest specs of my systemWelcome!
LOL, cart before the horse here...
That said, I have never heard of the brand of PSU... I will look and see if we can find an OEM to tell us, maybe, if it is a QUALITY unit or not. IF the PSU is of decent quality by the 750W badge it should be fine. THe thing is, I am not so sure about this PSU. Its a 750W model, and most modern PSU's have nearly all of their output on the 12v rail(s) since that is where modern PC's pull the vast majority of their power from. 540W on the 12v is what you have. Again, assuming it can output, cleanly, that full 540W it should be ok (assuming you are not using an AMD octo core overclocked), but leaves little headroom for anything else. What is the rest of your system? That information would be incredibly helpful to have...(create a signature!!!).
EDIT: According to this, it looks to be a Channel Well OEM which, in general, is solid (there are MEH ones though). It just seems that because there is so little wattage available on the 12v rail compared to its badging, this is an older spec PSU or something...
Well... AMD FX chip overclocked and 2 760's? That is could be cutting it close. If you start having issues under load, the PSU is the first place I would look.
In my signature is a link to a list of QUALITY PSUs. Grab a 750W off that list to be safe if this does not work.
I think you need to, as I already said, look at the list in my signature for a quality PSU and choose one off that list at your website. Otherwise, you can be in the same position you are in now just grabbing another random PSU.
You really can't go wrong with the Corsair brand.
That is a Corsair PSU that should work for you, yep.
De nada!
I'm a gambler... so I would let it ride... but ONLY because it has a CWT OEM (which doesn't set my mind at ease too much, but is better than not knowing I guess).
Lag spikes? That is an internet thing. Did you mean FPS hit? That also has nothing to do with lack of power. GPUs are not like lightbulbs in that the less power you give them the lower the light or FPS...
As far as the monitors, no idea. See which one you like better.
