maybe not normal but acceptable. the temps seem a bit high for a stock system but nothing harmful. also room temp plays a big role on your computers temps.Joki said:Ah ok. I'm not overclocking with stock cooler, got one 120mm intake, one 80mm intake, one 120mm exhaust.
So what you'r saying is that this is normal ?
Molester said:is this a 3600+ Windsor or Brisbane?
AlabamaCajun said:These 3600X2s are Brisbanes, there is a 3600X2 windsor with 256K L2 like a DC Sempron.
tux08902 said:Either way, it should not be this high. 55C under load? That is not good. My X2 3600+ idled at 19-21C on stock, and it still does so at 2.8 GHz with 1.325V. Although, I'm running a Freezer64 Pro, but that isn't an extremely amazing cooler. It just has very good priceerformance.
What is your Vcore setting? If it is at auto, then you might be giving it too much voltage? Again, I've given mine 1.4V and it still hasn't gone into the 50s under load, so I'm not sure what is going on. I suggest you get Core Temp, install that, and report those temperatures to us. I think your sensor might be screwing up.
AlabamaCajun said:I just bought a Thermaltake CL-P0047 with heatpipes. I was fine with a copper sink until I kicked in both cores for hours on end. No reboots but the temps were getting into the 50s. My other 3600 under a FX 4 pipe sink, has been in the 40s.
Give the Artic Silver a few days to settle, the temps will drop another 2-3 degs.
AlabamaCajun said:Case temps are in the upper 20s to low 30s as this is an open shelf. I am resolving some stagnating air problems but I have pusher fans forcing in cool air but the pusher may be recirculating some warm air. The non-pipe current sink is ok for non-oc chips but is a not pulling heat fast enough for higher chips.
