- Jul 12, 2012
So, recently I bought the A10-5800k and also bought the Cooler Master TX3 with it to keep it's temp in check.
It keeps it in too good of check, I decided to overclock.
Now, I installed this cooler and CPU on an OEM motherboard, so the BIOS was locked from OC'ing. My only resort was to use the Vision Control Center and activate Overdrive.
When it raised the voltage from 1.3 to 1.4v, it ran the auto-test in those clocks. However, when I try to run the clocks (higher than 4.2, because 4.2 does not cause a higher voltage output. If I go beyond 4.2 without raising the voltage, my computer will lock, and I have to force reboot), the CPU clocks back to 3.4, instead of the target speed.
Can anybody explain the reason for this? Does this have to do with the motherboard?
if you need the motherboard info, it's right here:http://h10025.www1.hp.com/ewfrf/wc/document?docname=c03343058&lc=en&cc=us&dlc=en
