- Mar 24, 2004
I swapped my HIS coolers out today on my x1900 crossfire setup with Accelero X2's. I was hoping for around the same temperatures, but with the ability to not hear the fans.
After about an hour of cleaning off the pads, the GPU, and installing the coolers carefully I got what I wanted, sort of.
The fans run at 100% speed after I modified the bios and was happy to find that I couldn't hear them at all. Then I got into windows and found out that my temps were on fire...
At 33% fan speed on the HIS coolers, my idle temp was around 40c. In games the fan speed would stay around 50% or so and the temps were 70-80c or so.
With the Accelero coolers, at 100% fan speeds, 2d clock idle temp was 63c... yikes. At 3d clocks/voltage (without even running a 3d program), the temp was idling at 83c. I took off the side of my case with the AC blowing into my computer and the idle temp was 77c.... Did I not use enough ceramique? Why are my temps so high? I thought maybe I would have slighter higher case temp (which went up about 4c, but that's okay), but 20c+ RAISE in temperatures? I am thinking I did something wrong.. but I did everything extremely carefully, made sure the pads were all on correctly, that I applied enough ceramique without too much or too little, made sure the heatsink was firmly on the pads and the chip... but it seems like I am not getting contact.
The temperature is actually low on one of the cards..., almost what I expected. 50c idle at 3d speeds. Did I just not get contact on my Crossfire card (the one with the high temps?) I guess I have to take everything back out again and look. Blah.
