- May 23, 2008
- London, England
How about a LM335 to a differential amplifier with a reference voltage set by a rheostat, then amplified to scale from 0 to 12V? The output can go into a NPN to set the fan voltage (which scales with temperature, with a set offset).
Sorry I don't have any circuit drawing program on this computer.
HERE is a link to the full size pic of the mockup. The top left variable potentiometer regulates 0-100% output with a 13Kohm-50Kohm range. (A thermistor with a 10-100k resistance in your temp range would would be a good candidate) The bottom left variable is set at 33Kohm, and can be used to adjust minimum speed of fan. The top right variable is used between the npn transistor and the MIC502 output. Its value is 270ohm and can be replaced with a fixed resistor. The circuit could still benefit from some smoothing capacitors here and there, but it does work.
As far as powering fans, you are limited by the transistor used at the output. As an example, I used a TIP122 from Fairchild Semiconductor. It is rated at 5amps continuous.
It had no problem powering 3 of my delta fans. Without active cooling, the transistor does get a little hot (50-70*C), but that is well withing its operating temp. In addition its suggested to have a small heatsink on it, which I didn't put on. The breeze from the 3 fans in the picture, was enough to keep it at 30*C.
Here are some shots with 25%, 50%, 75%, and 100% duty cycle output(duty cycle output is the percent of time a signal is ON at any frequency.)
The temperature stayed within 15 degrees from room temp at full power with 3 fans blowing on the transistor. Without any cooling , the temp shot up to about 70*C in a 20*C room. I also have another candidate to power some fans.
The one on the right, is what I am currently using. It is rated at 5Amps (60Watts). The one on the left is a MJL3281A by ON semiconductor. It is rated at 15A (200Watts)
I will keep messing around with it.
I have used the LM335 numerous times and it is a solid idea. The circuit is very simple to make, and definetly cheaper, but the fans might suffer from startup issues with low voltage output at lower temperatures.
Good information here. Is there any way I can talk you out of a list of parts that you used to make this controller? Also, how hard would it be to add three 3 pin connectors to use with the fans, instead of soldering them to the board?
Hey guys, how is this project coming along? I'm thinking about making my own to control 6 delta fans (about 50 watts). and dunking the thermistor into my reservoir. What I don't understand is what type of thermistor or if I need an extra resistor in parallel with it???
