- Aug 19, 2002
- Redmond, Washington
On the alternator front, even if it's not powerful enough, you can go to any car stereo place and pick up one that would probably power your whole house, so don't fret about that.
If the power supply is a standardized size (ATX) and the case is, then it HAS to fit, or it's false advertising.
If it's a QUALITY power supply, it should power a P4, although I highly doubt you need 2GHz in there. If you can get your hands on a mobile P4, then you're on the right track (lower power consumption).
Z
EDIT*** I looked at the case. It's an ITX case, it says, although I don't believe that. If it's not ITX, then it's MATX. Either way, the PSU that comes in it is a 150W unit, so 250W is definitely more. However, there are no specs for the PSU it comes with, so I can only assume that it offers high amps on each of the voltage lines. The PSU you linked to is weak in all areas when it comes to amps, at least compared to regular desktop units. I don't think you're going to be able to use an AGP card, certainly not a high powered P4.
And the measurements of the PSU you linked to are "(W x H x D )
150 x 86 x 142 mm/ 5 7/8"x3 3/8"x5 1/2" ", so find the specs of a normal ITX or MATX PSU, and compare. You can find them on Newegg.
Z
Z
Z
