Okay. Well I would rather be on the edge, then over it. It means at the voltage I am at, I have a little space to experiment a little.Sabertooth does that often, but even then you're right on the edge of the safety zone ?
The board and the temps jumping have nothing to do with each other. Its a function of the stress test.
It is possible the different drivers made it do that, but not the board. Boards are, for all intents and purposes, dumb. Without drivers and a program, they don't do anything.
Tell us more about your "custom" water cooler. I note that the pump is exceeding 5k rpm. That's very high! Is it noisy? What kind of fans are you using on the rad? How thick is the rad?
What kind of WC setup do you have? Looks like it really isn't doing much for you. 61° at 1.4v is too high IMO for any water system. It isn't one of those cheap ebay jobbies is it?
If you want WC XSPC and others make some decent "starter" kits. Just get something with a decent pump (D5) and at least a 2x120 (240mm) rad for that CPU 3x120 would actually be ideal.
