Well I have decided to add a gpu block to my 260. Just need to decide what is going to be the best upgrade to my current loop to deal with the added heat.
Right now I just have a single cpu loop with a gtz block, swiftech mcr220 rad and swiftech mcp655 pump. This loop works very well with my i7, but I know that adding a hot gpu will put added demand.
I am currently looking at 2 options.
1. Get a fesser 320 radiator and swap out the swiftech.
2. Add the antec top mount rad to my antec1200 case. this radiator mounts in the top of the case under the large fan. I would add this to my loop between the cpu and gpu.
