eXCeSS said:http://www.ocforums.com/showthread.php?t=78055
And your guys' argument: "longer in the rad = better cooling"
dont argue with excess cause he knows everything bout wcing gg
Our systems aren't open, though. We aren't dealing with throwaway packets of water that leave the equation once they've passed the component in question. We have one continuous packet, so that "packet" is constantly in the radiator and constantly in the blocks, all at once.clocker2 said:(Fluid) needs to travel slowly enough through the blocks and radiator to pick up/shed the heat.
Lol, great analogy.Sean Lindstrom said:Try running in rain for five minutes and see if you don't get just as wet as if standing in it for five minutes.
Neither of these "experiments" strike me as being particularly relevant to the conditions we are discussing. The frying pan trick is particularly egregious. Obviously, in a open system as you posit, the water can be converted to steam thus releasing heat more efficiently. My system doesn't get that hot, does yours? If the frying pan example were valid then the obvious first choice for a cooling system would be a waterfall, not a clunky and inelegant pump/radiator device.Put two identical frying pans each on an electrical plate at full burn. Wait 5mn. Put the first frying pan under a *thin* stream of water, almost dripping. Place the second pan under a full flowing stream of water. Wait 5 seconds. On which pan do you want to put your hand ?
Even a casual reading of my posts will reveal that I never said any such thing.And your guys' argument: "longer in the rad = better cooling"
And THAT is completely wrong, according to:clocker2 said:It needs to travel slowly enough through the blocks and radiator to pick up/shed the heat.
I still disagree with this assertion, Laws of Thermodynamics or no.So higher flow -> better heat transfer. ALWAYS.
Oh please. You didn't even read my posts. That's EXACTLY what i said, in a watercooling loop the pump heat input will make diminishing returns and even losses at high powers. Oh, read above...clocker2 said:To the original thread question "How big is too big" I now say that I have no idea other than there IS a "too big".
Perhaps in a perfect theoretical water loop this hold true.
AFAIK, no such creature exists.
As various people told you there: the thermostat is meant to HEAT up the engine to proper temperature. When the engine needs proper cooling, the vanes are full open for maximum water flow. Hey, would they be wrong at howstuffworks, and my car mfger would be wrong too ??? How's that for "real life" Mr. "i don't believe in the laws of Physics and i even call them theories.."clocker2 said:It was an imperfect and incorrect way to explain a phenomonon regularly encountered at the racetrack.
Of course I did. I even quoted it. Which you have deleted.Oh please. You didn't even read my posts.
Just so.As various people told you there: the thermostat is meant to HEAT up the engine to proper temperature.
(edit) there is indeed a point where flow will lead to increasing temps - when water starts to boil out of friction. What is required ? 10000gph ? 100K gph ? more ? and even so, pressure would push the boiling point upwards. Cavitation can lead to premature boiling too, but again one needs a very very strong pump, and rigid tubing, as the soft tubing we use in our WC setups would collapse long before it happens...
What a luxury...having one's cake AND eating it too.So higher flow -> better heat transfer. ALWAYS.
fafnir said:
Having spent the better part of the last year devising and tinkering with maybe a dozen different air configurations I believe that yes, after a certain point, lower flow is better.ha and think about our air cooled friends. With air cooling, is lower flow better ? Explain.
fafnir said:so for the title of the thread, there is no "TOO BIG"
for the pump or the radiator or the waterblock
BIGGER IS BETTER
just think about it, wouldn't you want a BIG-ger paycheck?
even if it indicates only the physical size of it, wouldn't bigger be better still
clocker2 said:Higher flow rates (i.e. unrestricted radiator intake), which intuitively should result in lower temps, do not always do so. there is a definite sweet spot, beyond which temps will again rise.
Surely pump heat can be a factor, but I also suspect other contibutory effects also.
Never heard a straw man say that before.clocker2 said:Mea culpa.
Oh come on.Korndog said:no, pump heat is the only factor.
