- Jun 22, 2003
- Amsterdam, NL
You made your point, but if you could maintane a low head with infinite flow rate, he is still correct.
SureFoot said:Dude, stop trolling please, this is totally irrelevant.
from SureFoot's post #23At what point does a water pump get too big?
Explain please why you think I am trolling.You want the maximum flow, both in your waterblocks and in your rads.
clocker2 said:from the original post...
You have made several unequivacal statements, the gist of which is "bigger is better".
When I question this I am accused of not reading the responses, failing to understand the responses and now, trolling.
How come?
Etacovda said:"The reason behind why increasing flow in an automobile can cause it to overheat is this. First when you increase flow you transfer more of the engine's heat to the water. Since you haven't changed the radiator or the air flow over it, the radiator can't handle the extra heat being transfered. It's size and the airflow limit how much heat it can remove from the water. When you excede the limit of the radiator the water just continues to heat up until it's boiling point is reached. Overheating.
I think it's a bad analogy because of this:
Car: 125,000 Watt heat source --> 900 cubic inch radiator
PC: 70 Watt heat source --> 70 cubic inch radiator
AND
A car has a different design goal for the cooling system.
Ever had a car that didn't run right until it warmed up?"
From that thread - Tried running two of the rads you're using in series, rather than the one, with a higher flow?
Etacovda said:When there was no thermostat in my car, it NEVER heated up.
More flow, more cooling, no regulation. SIMPLE REALLY ISNT IT.
clocker2 said:And you were running your car at redline for hundreds of miles at a time right?
Thought not.
Please try to remember that I am talking about race cars not your street vehicle.
Besides, if my automotive examples are going to be dimissed as irrelevant and non-germaine, then so should yours.
Rpkole said:well if yall want i can sale yall some pumps from my work they have a flow rate of 300+ gallons per minute not hour and have a head of 300+ feet the only problem you might have is going from a 6 inch outlet to a 1/2 inch tube
matttheniceguy said:[.......]
Ha, my thoughts, exactly, just in better englishmatttheniceguy said:There are of course practical limits for a computer. The difference between a 300gph pump with 2m head and a 3000gph pump with 20m head will only be a couple degrees so why bother with the trouble. For most systems a good 300gph pump is plenty.
Good ideamatttheniceguy said:As far as the car questions, it could be from a lot of things. First of, you want the engine to be as hot as it can be without causing knock/detonatio/NOx emmisions, so it's not quite the same thing. As for your car overheating when you remove the flow restrictor... hmm... that's a strange one. This is a total guess, but is the flow restrictor put on a tube that will bypass the engine? I don't think your waterpump would appreciate you totally stopping water from going through it, so maby the system you saw this on was set up to that the engine and tube with the restrictor were run in parallel intead of series. With this setup, when you blocked the flow with the restrictor, all the water would go through the engine. If the restrictor were removed, most of the flow would go through the tube and not through the engine. I haven't seen a car set up like this before, but who knows.
Not the reason. While what you say is correct, it dosn't apply here. The amount of heat dissipated is a constant. You will always dissipate the same amount of heat out of the cpu, always. The law of conservation of energy can't be broken either. It is the temperature that the dissipation takes place at, that is the concern. This depends on the radiator. The radiator is more efficient at high temperatures, less at cooler temperatures for the very reason you just gave. The cooling system will adjust temperature until the radiator disipates heat at the same rate as the cpu is producing it, which remember is CONSTANT.matttheniceguy said:When the water flows through whatever it is cooling heat is transfered to the water. The bigger the temperature difference the more heat is transfered. Whis is why cold water will cool something faster than hot water (pretty obvious ah?) So, when the water is flowing through whatever it is cooling, the water heats up as it flows through. As the water heats up, the temperature difference decreases, so the water doesn't cool as effectivly. If we push more water through the system, the "warm" water is pushed out faster, and the temperature difference remains high, so it will remove heat better. This is one reason a higher flow rate is better.
