QuietIce
Disabled
- May 7, 2006
- Anywhere but there
I recently had problems with our front page address links while using IE7. Don't know why there was a problem but there was. After several attempts to work around it someone asked why I hadn't upgraded to IE8. Well, I'm kind of a conservative when it comes to upgrading software - I've had waaayyy too many instances over the years where an upgrade not only killed the SOP but sometimes killed a whole program (in the case of an OS "upgrade"). But in this case I went ahead and installed IE8. Well, the address problem was fixed but now the main thing I liked about IE7 no longer works. It used to be that when a Favorite wasn't used for awhile it would disappear from the drop-down, which isn't happening in IE8.
In addition to the Favorites not being nice the download folder for pics jumps all over the place. I'll open a series of pics in new tabs from thumbnails on the same page. As I flip through the tabs to save the pics the download folder won't stay put. First it's My Pictures, then it's the last folder I used, then it's back to My Pictures again - back and forth and it's very, very random which will come up. I am SOOOOO sick of IE8!
- I've checked the box under options in IE8, it's set right.
- It's been long enough (more than two weeks) that this should have kicked in.
- I do NOT want to use Firefox because it's Favorite menu is even more screwed up (as are it's dl routines, IMO).
I want my old IE7 back ...!!!
I've gotten to the point I'd just like to uninstall IE8 and re-install IE7 (if someone here can't come up with a way to get IE8 working correctly).
- Is the cookie format the same so I can copy/paste after the switch?
- Is the Favorites folder the same format for back-tracking?
- Anyone have any explanation or work-around to make IE8 work the way IE7 did?
