Remacc.RAServer
Last Updated on: October 01, 2003 07:36:06 PM
Type: Remote Access
Publisher: TWD Industries
Systems Affected: Windows 2000, Windows 3.x, Windows 95, Windows 98, Windows Me, Windows NT, Windows Server 2003, Windows XP
Systems Not Affected: DOS, Linux, Macintosh, OS/2, UNIX
Removal: Low
Damage: Low
detection
# Intelligent Updater Definitions*
September 19, 2003
# LiveUpdate™ Definitions **
September 24, 2003
Intelligent Updater definitions are released daily, but require manual download and installation.
Click here to download manually.
LiveUpdate definitions are usually released every Wednesday.
Click here for instructions on using LiveUpdate.
This threat can be detected only by Symantec products that support expanded threats. For more information on expanded threats, please go here.
summary
Behavior
Remacc.RAServer is a component of the remote control software, Remote Anything.
Remacc.RAServer can be used for malicious purposes, as it allows a hacker to control a user's computer. And therefore, Remacc.RAServer constitutes a security threat.
Symptoms
The existence of the file, Slave.exe, is usually in the %System% folder.
Note: %System% is a variable. By default, this is C:\Windows\System (Windows 95/98/Me), C:\Winnt\System32 (Windows NT/2000), or C:\Windows\System32 (Windows XP).
technical details
File names: Slave.exe
Remacc.RAServer can be run in stealth mode. When Remacc.RAServer is executed, it performs the following actions:
1. Copies itself as %System%\Slave.exe.
2. Opens a port and listens for remote commands. Examples of opened ports are TCP 2639 and UDP 5048.
removal instructions
1. Update the virus definitions.
2. Run a full system scan and delete all the files detected as Remacc.RAServer.
For specific details on each of these steps, read the following instructions.
1. Updating the virus definitions
Symantec Security Response fully tests all the virus definitions for quality assurance before they are posted to our servers. There are two ways to obtain the most recent virus definitions:
* Running LiveUpdate, which is the easiest way to obtain virus definitions: These virus definitions are posted to the LiveUpdate servers once each week (usually on Wednesdays), unless there is a major virus outbreak. To determine whether definitions for this threat are available by LiveUpdate, refer to the Virus Definitions (LiveUpdate).
* Downloading the definitions using the Intelligent Updater: The Intelligent Updater virus definitions are posted on U.S. business days (Monday through Friday). You should download the definitions from the Symantec Security Response Web site and manually install them. To determine whether definitions for this threat are available by the Intelligent Updater, refer to the Virus Definitions (Intelligent Updater).
The Intelligent Updater virus definitions are available: Read "How to update virus definition files using the Intelligent Updater" for detailed instructions.
2. Scanning for and deleting the infected files
1. Start Norton AntiVirus and make sure that it is configured to scan all the files. For more information, read the document, "How to configure Norton AntiVirus to scan all files."
2. Run a full system scan.
3. If any files are detected as infected with Remacc.RAServer, click Delete.
