Hi
am starting to think of building a new desktop and i discussed this here:
https://www.overclockers.com/forums...ghest-end-builds-so-far?p=8156874#post8156874
might go with the ASUS ROG helios due to local availability here in Turkey...
will probably use this motherboard:
https://www.newegg.com/asus-rog-crosshair-viii-formula/p/N82E16813119104?Item=N82E16813119104
and Three ASUS EKWEB 3080s for mining (yes mining not gamming !...)
now i need to plan for the liquid setup end result to look something like these:-
How do you plan for your build and know which parts to get to achieve such a final look ?
for example in most builds hard tubing go in straight lines, am sure with a the wrong parts you cant achieve this look !...
is there is an online building tool where i can design the rig before ordering the parts ?...
what if i dont want to bend the tubing myself ? can everything be ordered from somewhere just for me to assemble it ?...
sorry to sound super naive but am still on soft tubing and not sure where to start to achieve such a professional look !...
thanks...
thanks...
