- Jan 5, 2005
- Ormond Beach, FL.
For those that have the tube type reservoirs....how do you fill and bleed the system when you use the fill port for the inlet? I have seen some reservoirs with two inlets, so that one is a no brainer.
What do you do, remove the tube, fill up the res, put the tube back on, run the pump, and continue until full? Even then how do you bleed it?
