Well my Gigabyte 7600GS comes factory overclocked to 450mhz... So it's safe to say you should probably be able to do 500mhz pretty easily with a decent fan on there...
But I never saw the point in overclocking older video cards... You'll never get it high enough to MEAN anything because you have DDR2 ram in there instead of DDR3.
I'd like to get an X1950XTX now that they're cheap so that I can play around with DDR4.
Volt mod and you'll hit up to 700Mhz on the core, with water. However it doesnt mean much as the core is bottlenecked by the slow RAM. You wont get much on that RAM, even with a volt mod you'll probably only get up to 420Mhz.
In the end, you wont see much increase in fps, but you can crank up AA and AF and the core wont struggle at all
First, we tweaked the Vgpu from 1.1V to 1.8V and saw a massive clock increase from 470MHz to 720MHz. That is a massive 80% overclock over the 400MHz original!
