How is this build so far?
taylor2
just getting some opinions on this build so far this computer will not be for rendering anything or any kind of editing it will be for school and Heavy gaming
Shopping Cart
Qty. Product Description Savings Total Price
1
SAMSUNG 22X DVD Burner SATA Model SH-222BB/BEBE - OEM
Item #: N82E16827151244
Return Policy: Standard Return Policy
$16.99
1
Rosewill CHALLENGER Black Gaming ATX Mid Tower Computer Case, comes with Three Fans-1x Front Blue LED 120mm Fan, 1x Top 140mm ...
Item #: N82E16811147153
-$10.00 Instant
$59.99
$49.99
1
SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Item #: N82E16822152185
-$10.00 Instant
$99.99
$89.99
1
ASUS VS Series VS238H-P Black 23" 2ms HDMI LED Backlight Widescreen LCD Monitor
Item #: N82E16824236175
Return Policy: Monitor Standard Return Policy
-$40.00 Instant
$10.00 Mail-in Rebate Card
$199.99
$159.99
1
EVGA 02G-P4-3660-KR GeForce GTX 660 Ti 2GB 192-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card
Item #: N82E16814130809
Return Policy: VGA Standard Return Policy
$299.99
1
NVIDIA Gift - Borderlands2 Free Game Coupon
Item #: N82E16800999294
-$59.99 Saving
$59.99
$0.00
1
Antec BP550 Plus 550W Continuous Power ATX12V V2.2 80 PLUS Certified Modular Active PFC Power Supply
Item #: N82E16817371016
-$15.00 Instant
$79.99
$64.99
1
IMC IMC-black USB 2.0 Card Reader
Item #: N82E16820717001
Return Policy: Computer Cables and Accessories Extended Return Policy
-$9.99 Saving
$9.99
$0.00
1
RAZER Black Wired Laser Naga Molten Special Edition Gaming Mouse
Item #: N82E16826153064
-$12.00 Instant
$79.99
$67.99
1
G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL
Item #: N82E16820231314
Return Policy: Memory Standard Return Policy
$45.99
1
ASRock Z75 Pro3 LGA 1155 Intel Z75 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Item #: N82E16813157304
$84.99
1
Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000 BX80637I53570K
Item #: N82E16819116504
Return Policy: CPU Replacement Only Return Policy
$229.99
Subtotal: $1,110.90
Drop the GPU to a 7850 and get a better motherboard, it'll be worth it in the long run. Upgrading the motherboard is a pain and you don't want to get one with a lack of features. That's a really low end board, you can't add multiple GPUs and it has a relatively small power delivery section to the CPU, meaning it's not going to overclock that great. Also, GPUs outdate very quickly, so it's a better investment to spend money on the part that lasts a longer time, like a PSU and CPU.
Also, no combo deals?
Skyrim Crysis 2 League of legends Wow Dead space 2
SHogun total war
pretty much what i had it at right around 1100 with a 170 dollar monitor and the naga
This comes out to $1130, not including a $15 Newegg gift card and $35 of mail-in rebates. This can overclock fairly high (4.5GHz+) and supports dual video cards in the future without changing any other part.
Options to change:
  • +$10 to get a 3570K instead of the 2500K. This will perform about the same (faster CPU but doesn't overclock as high, so it balances out) but draws a bit less power and has PCIe 3.0 support.
  • -$5 to get the Rosewill Challenger instead of the Rosewill Future. The main thing you lose is front panel USB 3.0
how did u get the power supply to bundle with the ram i ant find it anywhere
That's a good bit more expensive than what's posted above (above includes a monitor), and I sure as hell am not spending $1100 on a rig with a 550Ti on it.
550Ti is suitable enough for gaming, and anything larger isn't a real benefit unless you're get a Catleap Q270 or a large monitor with very high resolution. The card you selected is simply overkill for the monitor selected where you won't benefit any noticeable performance, but you'll pay a heck of a lot more for something (as you say) gets outdated very quickly.
EDIT: Also, the monitor is crap compared to the one you suggested I buy which cost less.
Suitable enough if you like gaming at ~45 FPS on medium settings. Even cards significantly more expensive than the 7850 can't run games like BF3 at max settings, 60FPS on 1080P.
How is a LG IPS monitor crap....they're the ones who actually make all the IPS panels.
We all know LG makes all the IPS panels, but not all monitors/displays with IPS panels are the same. You can't expect to get any kind of decent speakers in an IPS monitor at that price, and if a monitor does have speakers and is cheap like that, something IMO is being scaled back or sacrificed at that price.
Besides, that display has a stand like a Girraffe neck, which makes it top heavy and easy to fall over plus you can forget a VESA mount. For $10 more, that person could have one like the one I just ordered, which you suggested instead of the LG model. Newegg also has a LG IPS 23" for $20 more than that one without speakers, so why is the one without speakers worth more?
I would think because it is much better quality IPS display plus offers the option of a VESA mount. Suggesting the cheapest part may not always be the best advice unless you actually own one of such product or at least know someone who owns such particular product.
The stand is tall because its telescoping, the display is height adjustable. Look at the side view, the monitor can sit much lower than it does at the height where the pictures are taken.
The OP hasn't stated that he needs any of those features. Frankly, the large majority of people buy a monitor to do one thing. Sit on their desk and display an image. Why would I pay more for a different monitor that has the same LCD panel that will sit on my desk and display the image in the exact same way.
I tend to avoid recommending products based on personal experience. Personal experience usually introduce a large amount of bias and are also influenced by a large amount of variables, some that have nothing to do with the product.
That display looks alright to me. The speakers will be weak but you can't expect a whole lot from built-in monitor speakers. The only other thing I would consider is that it seems to have a bit of light-bleed on the left side (some searching confirms this from multiple reviews). Nevertheless, that will be minimal in games. For the price, it is a great choice.
