- May 22, 2016
How often is it recommended, if at all, to re-apply your paste to keep it in good condition?
After about two hours of non-stop NMS last night (I had to try the new patch and got hooked), I noticed my CPU temps had topped out around 76c. I didn't see what they were at under load, as it wasn't until I closed NMS that I saw the max temps and by then they were reporting in the upper 20's/lower 30's at idle. I know my loop isn't getting warm, as my GPU topped out at 33c during the entire two hours and it's in the same loop.
So, I'm wondering if reapplying paste is something people doing for upkeep? The chip is running a hair under 1.4v @ 4.8ghz so it's going to get warm, but I don't know that I've ever seen it run this warm.
I'll have some more time to play tonight, and I'm going to let it run for an hour or two and check load temps at that point to see where I'm at.
As an aside, is there a program that will show MIN/MAX/AVERAGE for CPU settings like GPU-Z does? HWMonitor only has MIN/MAX that I can see, I'd like the ability to see my average as well.
