- Jul 17, 2002
- In a Room Heated by Electronics
- Thread Starter
- #21
The Unforgiven said:oRIDDLERo, what did you have to do to get all of your wiring on the backside of the motherboard tray? I was wanting to hide all of my wiring like that, but wasn't really sure where to start. I see one hole cut in front of the PSU on the top. I have to say that is one incredibly smooth case modding job.
The hole you see cut at the top is just so the 1/2" T-Bend can get to the new fill port behind the MB tray. I thought this would be the neatest place to install it. I did however stuff a few wires through there because they were close by. B4 i had the fill port i just stuffed them all thought the pre cut away area behind the hard drives with no problem
mgoode said:outstanding!!!
What is that in your first 5.25 drive bay? it looks like a mini matrix orbital.
That is my good friend the "DigiDoc". It displays the 12v rail, the 5v rail, and has inputs for 8 thermal diodes ( i have them connected to CPU, GPU, GMEM, NB, Internal Ambient, FET1, FET2. Aux CAp1) It might look a tille different b/c i cut a new face plate from a lian-li aluminum blank with a dremal and files (this was NOT fun)
