I'm upgrading the low end video card in my Dell Optiplex 990, i7 2600, Vertex 3 MAX IOPS, 16 GB DDR 3 RAM, Seasonic 650 X Power Supply.
Currently have a low end AMD GPU which came with the system. Now that I've upgraded some other copmponents (particularly the power supply), the GPU upgrade is next.
Currently running on Win 7 64 Pro. Currently have the Catalyst Suite 11.9 installed for the AMD 6450 GPU. I want to upgrade to a GPU substantially better.
Can I just go to device manager and delete or uninstall the hardware (existing GPU) leaving the AMD Catalyst Suite alone. Then shut down and install the new card yet to be determined and restart the system? Is it that simple? I assume the CAtalyst Suite is apropriate for all current AMD cards?
Thanks.
kapalua
Thanks.
kapalua
