i tried to oc my monitor which i never tried before, but how do you tell if it worked?
i used this guide http://www.tweaktown.com/tweakipedi...s-pb278q-monitor-2560x1440-at-85hz/index.html
ccc only shows maximum reported refresh rate with at 1080p is 75hz, but im using 2560x1440 which at default is 60 but i have pushed it to 75.
just need a way to check it is at 75hz at 2560x1440. if i push to 80hz when i reboot i get out of range on monitor but it still displays the picture and amd does show as 80hz.
monitor is DGM IPS-2701WPH
edit this test says it is at 75hz but not sure how accurate it is http://www.testufo.com/#test=framerates&count=3&background=none&pps=960
