- Sep 29, 2012
- Fresno, CA
I have been attempting to do this for several days now, with no success, and not much help from the EVGA support forums.
It seems that something is missing. I have been using a CD (and now a DVD+RW after wasting a stack to prior failed attempts) to try and update my BIOS with a version 83.iso file. After the EVGA support finally clarified that I cannot just copy the files in Windows that I have to use a boot-disk, I have been trying to use a trail version of MagicISO, to no avail, at least thus far. Isn’t something missing here? I mean OK, I boot off my DVD and there I am with a .ISO file, how does the motherboard know to flash its BIOS from this? Isn’t there some other program or mode that needs to first be accessed or even an CTRL-command?
Also to note, the reason I need to update my BIOS is that each time I install the drivers for my EVGA 680GTX Classified, Windows will freeze during startup, I can now only access Windows in safe-mode, which also limits what I am able to do (using my GPU as a basic VGA card at this point). EVGA support is advising me that my motherboard is a too old (a EVGA X58 Classified 3), so I need to reflash the BIOS with an update and then my GPU should work fine. I am starting to think that maybe something else is going on here. Seriously, compatibility issues were the last thing I thought I was going to be dealing with in using both a EVGA MOBO and GPU, and yet here I am, one week into my build and four days spend going backwards, getting nothing accomplished.
And while attempting to resolve this issue, my problems have only gotten better (err... worse). After setting the BIOS to default as per the vague instructions for updating the BIOS, I can no longer warmboot, as the power to monitor will not reengage, which means that I have to switch the PSU to off, wait about a minute and then turn back on and press the case’s power button… I have to do this for each and every reboot, so far EVGA support can provide me not assistance as to how to stop this issue, which I am rather certain is just draining the life from all of the brand new equipment in my build.
I am really hoping for some guidance on how to properly solve these issues.
My primary issues are:
1. How to resolve loss of power to the monitor during reboots (this is very time consuming and is increasingly damaging my hardware).
2. The proper way to make a bootable disk, as I have never done this before using a CD/DVD (that MagicISO program has many options and several windows in it, I am not sure what I am suppose to be doing inside of it—and Windows will not let me install a free version of Nero while in safe-mode).
3. How to correctly flash the BIOS for the EVGA motherboard during boot or while posting.
* And one of my primary worries, is there any likelihood that the issue I am having with the GPU actually related to a failed piece of hardware within the GPU itself rather than just a matter of the BIOS being outdated (this just seems a little odd to me that a mere outdated BIOS would be the cause of all of this)?
