- Oct 13, 2004
Need some advice here-
I just bought an Asus XT8 router and I want to install one router downstairs and one router upstairs,
1) My house has pre-wired CAT5, however Im not sure that its CAT5e...is it worth considering hardwiring the 2nd mesh router upstairs if its just CAT5?
Here is how the wiring looks. I'm not use what exactly all this stuff is, but I assume I could removing the blue wiring and attach the jack port and then put a switch here?
EDIT: Nevermind...they are telephone cables, scratch that. I'd have to run all new wires which isnt worth it. Ignore thread/delete.
2) If its just CAT5 and not CAT5e, is the 100MB line not worth the work and just run the 2nd mesh router wirelessly?
Thoughts/advice?
Thoughts/advice?
